Removing VE Injection pump question
Old Jun 5, 2013 | 11:59 PM
Originally Posted by dan123dbl
Well I got everything off besides the pump from the drive gear. Sheared the bolt out of it. Gonna pickup some stronger bolts tomorrow and hopefully get the new pump in!
Ohh that sucks! Hope the gear didn't get wrecked? Make sure you chase those threads....and put a rag or something to try and catch the small metal pieces as your cleaning it out.
Old Jun 6, 2013 | 12:11 AM
dan123dbl's Avatar
The threads didn't look damaged at all so I'm guessing just weak bolts.. But it is kind of hard to see in there. They were from a steering wheel puller kit from the 90s. I'll post tomorrow with what happens!
Old Jun 6, 2013 | 09:14 AM
Smokin$$away's Avatar
As stated above be sure to put a rag below the gear. If it were me I'd get a tap to chase the threads just to be sure, grease up the tap with gun grease to help catch the cuttings. As Jim stated you can use the bolts from the grid heater, not sure how hard they are but I used them pulling my pump and I put alot of pressure on them. You may have a key that was installed offset just a touch off making it very difficult to remove, I know I've been there done that!! Good luck!!
Old Jun 6, 2013 | 09:24 PM
dan123dbl's Avatar
Well got the pump in and she runs! Tool it for a test drive and there's some white / grey smoke at wot. Does this mean I have to advance the timing a bit?
tommurray
Feb 23, 2014 10:38 AM
dzl_damon
Mar 19, 2010 05:17 PM
captain23
Apr 28, 2008 01:42 PM
vwfinder
May 15, 2007 12:30 AM
NeedMoPower
Oct 6, 2005 01:54 PM
