Removing the injection pump??
Old Oct 4, 2005 | 08:01 PM
NeedMoPower's Avatar
Hey guys,
The time has come and tomorrow I will be removing the injector pump in the old girl. What kind of tool is needed to remove the gear? Will a steering wheel puller work and can I borrow one at an auto parts store? I think I have everything else covered, but didnt know what tool was required for that particular matter. Thanks in advance...
Cody
Old Oct 4, 2005 | 08:03 PM
G1625S's Avatar
Just a standard gear puller, nuttin too special...but you'll need metric threads on the bolts
Old Oct 4, 2005 | 08:07 PM
DODGE 92's Avatar
ve pump
just do a search on recalls for the ve pump i saw everything you need there including diagrams i found it once good luck
Old Oct 4, 2005 | 09:06 PM
bgilbert's Avatar
Yep a steering wheel puller will do it. I used a cheap T style Craftsman wheel puller. If you don't want to go the parts store for the correct threaded bolt for the gear, use two bolts from the intake horn/grid heater. They are the correct thread as the gear. Stuff a rag into hole just in case you drop the key from the gear.
I'll give a dollar if ya take down that number from your gov spring .
It's really not that tough, don't let the book confuse ya.
Any more ?'s feel free to ask.
Old Oct 4, 2005 | 09:21 PM
Thanks for the info guys.
Bill, where did you buy the T-puller at, and thanks for the heads up on the intake horn bolts. I'll be sure to get a # off the spring when I start tinkering with the pump. Cashier check or money order will be fine...i'll pm you the shipping info.
Old Oct 4, 2005 | 09:26 PM
bgilbert's Avatar
This bad boy right here did the trick. Usually on the shelf at Sears. http://www.sears.com/sr/javasr/produ...id=00941833000.
Old Oct 6, 2005 | 10:34 AM
Well, the pump is off and it took just a tad over 2.5 hours and that included the time it took for fellow member JDGnut to build a gear puller. Come to find out the gear puller I borrowed would not work since it wasn't a "T" style so Bryan made something to do the job. The job went real smooth with two people working on it and I just hope it goes back on this easy.
Old Oct 6, 2005 | 10:50 AM
JDGnut's Avatar
Would have save us 15mins had we remove the return line before we removed the pump... That bugger (gear) was on there tight... One of these days I'll get a little puller.. and leave it at my shop... lol...
Bryan
Old Oct 6, 2005 | 12:47 PM
bgilbert's Avatar
Tell me about it!! Same here. Couldn't figure out why I couldn't pull the pump off the truck after pulling the pump gear , after a few tugs, I knew something wasn't right .
Old Oct 6, 2005 | 01:54 PM
Yeah, I felt like an idiot aftter I realized the return line was hooked up. Sad thing is after a few tugs and it didnt come off, I just tugged harder.
I was expecting this job to be alot harder than it actually was. Maybe installing the FASS system tonight will put up more of a challenge.
tommurray
Feb 23, 2014 10:38 AM
dan123dbl
Jun 6, 2013 09:24 PM
dzl_damon
Mar 19, 2010 05:17 PM
captain23
Apr 28, 2008 01:42 PM
vwfinder
May 15, 2007 12:30 AM
