removing dash
removing dash
The dash for the truck in my sig is badly cracked and i was wondering how hard it is to remove the dash. I am also looking for a replacement but hae had no luck yet. Any suggestions on what to do is appreciated.
You can use a pick to lift the weatherstrip up and see where the screws are. We have been able to cut a semi circle out of the rubber and remove the screws. Takes about an hour to remove and about the same to reinstall. What color dash are you after?
i am after a gray dash but if i can get one a different color i will paint it.
Mine was red and painted in grey and it turned out ok... Not the greatest but ok... Hard to keep it wet with a spray can to make it look uniform.. Good luck at getting to the screws, it has to be tight getting to them with the windshield in but would be worth the time to try... Popping the windhield out is pretty fun too...Well it depends if your trying to save it..lol
I would rather take the dash out again than take the springs off. It's not that bad and when you get it all back you'll know the inside of your 1st gen like no one else. It's really not that bad!!
I took the windshield out. There's a guy lives close that put it back in with a new seal. There may be a way to do it w/o taking the glass out. I've never tried that.
