Rear tires not turning in 4L
My dad was using my truck tonight hauling some cattle. He said he was backing the trailer up to the barn, when he got stuck. My cuosin who was helping him out said the rear tires weren't turning? Once he put it in 4H they were turning. What is in the TC that locks the front an rear together? I have never had a NP205 apart so I really don't know. It doesn;t make any funny sounds so I think the TC is ok, just something isn't quite right. BTW I do have another 205 in a 80' 3/4 gasser, what is the same and what would need to be swapped around to make it work?
DS79
DS79
ROB
Kick it harder The linkage is worn out/dirty and they are nitorious for not engaging 4 low. The shift rails can control the front and rear outputs independently if set up correctly. What is happening is the one closer to the center of the truck is not going all the way in for whatever reason.
ROB
ROB
I think that might be the ticket. I thought at some point I had it in 4L, but couldn't remember. I am sure the linkage just needs to be pulled off and cleaned up. My old 79 did the same thing, just had to use your foot a couple of times to get it into gear. Thanks for the help,
DS79
DS79
When was the last time you checked the fluid in the transfer case? Any leaks? I had the same problem when i bought the truck then it got worse and i lost 4H. I thought i was going to need a new transfer case but turns out it was just really low on fluid. Changed the fluid and everything worked. Just a thought.
Chris
Chris
05-29-2009 10:24 PM
sakisaki400
23
12-31-2006 10:17 PM
