Rear-end
Rear-end
Okay I need a little help.The rear-end is making some noises.When I put the truck in gear "Reverse" or "Drive" There is a clunk sound and there is a ticking-clicking sound at low speeds.Any Idea what this could be? I checked the rear-end fluid and adde some but it's still making noises.Any help would be welcome thanks.
Maybe a u-joint to. Jack one wheel up, leave it in gear and rock the wheel back-n-forth. You should be able to see, feel where the slack is.
Sounds like a siezed cup on the u-joint. You won't find slack, but if you drop the shaft you will find one cup(or more) doesn't spin, which is the squeak-squeak-squeak noise at low speed.
So how big of a deal is this? I'm not sure how to check the clutches.any advice? I might have a chance to check this out tomorow after work.But is this a serious problem or just an anoying noise?.
2500CTD
10-19-2010 07:10 PM
RichN
0
08-06-2010 06:52 PM
doorguy
06-08-2007 06:19 AM
royta
07-13-2004 06:54 PM
