Ran out of fuel
Old Oct 7, 2018 | 10:40 AM
TJE's Avatar
TJE
Ran out of fuel
folks I did the stupidest thing I’ve done in a while!! I ran out of fuel now the truck won’t start! What’s the steps I need to take get the truck running again?
Thanks!
Old Oct 7, 2018 | 02:06 PM
1320Fastback's Avatar
It's going to take a lot of bleeding so you're going to have to crack loose the fuel lines at the injectors and crack loose the 10mm vent bolt on top of your fuel filter.
Remove the fuel filter and fill with diesel and reinstall. Using the manual prime lever you need to have fuel flow out of the vent screw at the fuel filter. After you have fuel there close the vent screw. Using the manual pump again you then need to prime it until the injectors start dripping diesel. You probably will have to turn the engine by hand and prime again to bleed each injector.
It's going to take a while to get all the air out and dont use the starter to try and move fuel thru the system as the injection pump is lubricated by fuel and it is now empty.
Old Oct 7, 2018 | 10:23 PM
TJE's Avatar
TJE
Thanks! I finally got it started....
Old Oct 8, 2018 | 12:11 AM
Angry Johnny's Avatar
Bet you won't do that again.
jefe4x4
25
Dec 15, 2011 07:33 AM
Deadbunny
Mar 29, 2009 10:17 PM
Buckshotmckee
Jun 10, 2005 12:23 PM
shawndennis2
Mar 30, 2003 10:06 AM
