Dipstick tube
Old Oct 2, 2018 | 07:34 AM
Tns's Avatar
Tns
Dipstick tube
I’ve been lurking and learning but this is my first post I’m having a burnt 5.9 rebuilt that had a fire and melted the dipstick tube cummins quoted 500plus crazy any ideas?
Old Oct 2, 2018 | 02:47 PM
edwinsmith's Avatar
I dunno but I'm thinking maybe getting into the used Cummins parts business like Oliver. I'm sure he has one for a reasonable price.
Edwin
Old Oct 2, 2018 | 02:54 PM
you can try car-part.com....but most will probably not want to part out the dipstick from a complete motor. E-bay and other on-line sources would probably be the best way to find one. Sure they used the same dipstick from 89-02-ish....????
1 min search on E-bay netted me this one....used - &70 from a 93 motor. (FYI - E-bay links not allowed on the board....just copy and paste.... )
eBay item number:202452097944
Old Oct 3, 2018 | 12:07 PM
bannerd's Avatar
I built one on the 4bt engine I'm redoing. It was from a stainless steel brake line, I was able to get the rubber grommet from the local marine shop. Tig welded a washer around it and left enough to press into the grommet.
I didn't have the size... it was a lot of work making sure the dip stick to oil level was right. Just made sure oil was above the pickup tube so that was low oil and high oil was over the tube but under the oil pan seal. I think they wanted $180 for the 4bt engine and I spent probably $30.
Old Oct 3, 2018 | 03:07 PM
Tns's Avatar
Tns
Thanks bannerd do you know if I can just cut off the tube off another 5.9 I have and use it on the rebuild
Old Oct 4, 2018 | 10:14 AM
kensmachine's Avatar
When I bought my 91.5 the dipstick tube was broken at the block I got a new one from Cummins I can't see a new tube being that much money.
Old Oct 4, 2018 | 10:54 AM
Tns's Avatar
Tns
Just called different Cummins dealer part number 391 8385 612.00 Nashville west pay I think was 568 insane
Old Oct 4, 2018 | 10:56 AM
Tns's Avatar
Tns
Sorry for the typo Nashville 612 west palm 568
Old Oct 4, 2018 | 11:12 AM
patdaly's Avatar
You could always change it over to the second gen sty;e, not discontinued, and much cheaper, like 70 bucks new for both parts. Much cheaper still used on fleabay.
Second gen number for tube is 04761975 and stick is 04883345
First gen is 4429800 for tube and 4429117 for stick.
Old Oct 4, 2018 | 12:32 PM
Tns's Avatar
Tns
Thanks patdaly
Old Oct 8, 2018 | 07:23 AM
bannerd's Avatar
Sure, don't cut it off... just remove the one bolt (or two if the did the midway) and pull the tube out. Some of them are plastic so good luck with those. The oil seems to make them very brittle.
1985cucv
15
Apr 17, 2009 09:06 AM
Dean Snow
Sep 21, 2007 01:18 PM
signature600
Jan 3, 2004 02:24 AM
Jambbii
Nov 24, 2003 11:14 PM
