radiator swap
Old Dec 4, 2010 | 11:38 AM
wise_cummins's Avatar
radiator swap
I have a 90 non intercooled looking to change radiator to the cross flow just wonering if anyone had pictures of how they modified the core support and a parts list of what I need to do the swap thanks for the help
Old Dec 4, 2010 | 03:50 PM
rebal's Avatar
I dont have pics. but its real easy to do.
the left and right side of the core support needs to be cut down 2" or so. 2 holes drilled in the frame for the rubber bushings on the bottom of the rad. 2 upper rad. mounting brackets ( can be made). you can use 3 upper hoses cut to get water over to new inlet of rad.custom made shroud ,I dont have a shroud any more mine broke and fell in the fan ...disintegrated but I have no issues with heat any more.
if your wanting it to look stock you will need new fan/fan hub/tstat housing/shroud I recommend a t stat housing. a doner truck would be nice but not needed
Old Dec 4, 2010 | 07:23 PM
TIMMY22's Avatar
I did mine also, real easy. I actually modified a gasser support to fit cross flow diesel.
A cut off wheel, mig welder and some paint.
8liter
Sep 22, 2012 10:19 AM
bigwheels94
Jul 11, 2008 03:10 PM
Treangen
63
Jul 7, 2008 07:42 PM
Redleg
Oct 14, 2005 07:45 PM
gwhammy
Jul 9, 2004 07:49 PM
