Radiator Exchange ?
Old Apr 5, 2023 | 12:46 PM
whosdunit's Avatar
Radiator Exchange ?
I have a 1990 d350 w/ a old rad., have a 1992 d250 w/ new rad. What problems will i encounter if i try to swap the 92 rad., into the 1990?
hav'n coffee,, whosdunit.
Old Apr 5, 2023 | 07:20 PM
u2slow's Avatar
The 92 intercooled rad mounts completely different, and the top hose connections is opposite side. Check rockauto for pics.
Old Apr 5, 2023 | 08:45 PM
whosdunit's Avatar
U2slow, thank you for your help, owe you a coffee.
coffee's ready,, whosdunit.
Old Apr 6, 2023 | 06:44 AM
To use the later rad, you ALSO will need...
Fan hub.
Clutch fan
Fan shroud
Upper radiator neck and hose
Different mounts on the core support for the radiator or swap out the core support.
if you swap out the core support the grille and lower valence will need to be swapped too.
Old Apr 6, 2023 | 09:17 AM
whosdunit's Avatar
Thank you Oliver,i will have everything i need from the doner trk. I want to replace the water temp. sender also but not sure if i need a 27mm or 30 mm socket ( what are these in standard sockets?), owe more coffee.
coffee's ready, whosdunit.
Old Apr 6, 2023 | 04:41 PM
Might be easier to just swap over the whole rad support and then relocate the headlight buckets to line up with your 90 grille.
Old Apr 6, 2023 | 05:40 PM
u2slow's Avatar
Since you have the donor truck, imho, swap all the parts to make it work.
The upper water neck (to point the other way) is readily available aftermarket... if you don't want to pillage that off your otherwise complete IC engine.
Old Apr 17, 2023 | 03:54 PM
KevinBoles's Avatar
Which one did you use?
Spoiler
Old Apr 17, 2023 | 08:27 PM
whosdunit's Avatar
Hey Kevin, to be honest, by the time i flushed my old rad, (3 times),and installed a new temp sensor everything is working fine. But i still want to swap the whole 92 rad. package, later this year.
u2slow, yes i agree.
charliex25
Aug 30, 2006 11:55 PM
OLDDDOGS
Nov 28, 2005 12:11 AM
smokNjoe
Jul 4, 2005 01:13 PM
bigdogtruck
Jun 15, 2004 05:44 PM
