Quick Brake question - Rear Wheel Cylinder
Old Mar 10, 2008 | 02:28 PM
Loopi's Avatar
Ok, got a 92 1 ton dually...assisted and more experienced about a year ago in doing the brake job and that whole pull out the axle thing was a bit daunting for me...So, what all is involved in R&R on a rear wheel cylinder? I push the brake and it dribbles out from under the drum/hub so I assume I am thinking correctly in assuming most LIKELY it's a cylinder...Driver's side if that makes a difference.
If so (on the axle question), is there a guide or something on doing this, it looked kinda like something that was not for an amateur.
James
PS> The transmission is finally PRETTY good...for those who remember.
Old Mar 10, 2008 | 02:58 PM
Charles C. Stan's Avatar
If it were my problem I would take it to a good brake shop and let them mess with the job of dismantleing the year axle. I was amazed at how fast they could do the job. But of course they do that every day.
Old Mar 10, 2008 | 04:06 PM
Loopi's Avatar
Is the chevy cylinder a drop in replacement? Worthwhile?
Old Mar 10, 2008 | 04:42 PM
There's a link to an article about pulling the drums in the sticky. It's really not that bad, the only special tool you need is the 2 9/16" socket.
http://ramchargercentral.com/boards/...owtoshow;id=66
The Chevy cylinder bolts in - just make sure you do both sides.
leeboy
May 10, 2013 09:10 AM
Gen414
May 7, 2009 11:08 AM
cgmorgan06
Nov 15, 2007 04:02 PM
csramsey640
May 15, 2006 08:23 PM
Journier
Nov 22, 2004 02:56 PM
