3" rear shoe/wheel cylinder install ??
Old May 14, 2006 | 07:59 PM
csramsey640's Avatar
OK I am having a hard time locating some info, on both.
If I goto 3" rear shoes, can I then still use the Chevy rear wheel cylinders, or do I need the correct wheel cylinders shown in the "how to do" section?
I plan on doing the install soon, and want to "do it right"
Old May 14, 2006 | 08:37 PM
Trebor's Avatar
When I replaced my rear drums I went from the 2-1/2" to the 3" shoes. It was nothing more than replacing the drums and shoes. I used new 2-1/2" mounting hardware with the new original type 2-1/2" drums and never changed the wheel cylinders. I have had no braking problems since the installation which was just over 2 years ago. You can reuse your 2-1/2" drums if they are good but you will need to have them turned to clean up the 1/2" lip that the 2-1/2" shoes do not come in contact with.
Old May 14, 2006 | 11:15 PM
fishin fever's Avatar
Now I'm no whiz kid but, you have the rare single wheel 1 ton. Key word 1 ton .. so I'm thinking you may allready have the 3' system .A vin check at the local dodge dealer should tell you.
Old May 15, 2006 | 08:47 AM
spunbearing's Avatar
Yep you should already have the larger wheel cylinders and shoes. When I got mine I asked for the 1 ton cylinders and 1 ton shoes ( 3 inch). When I got mine apart I found that I already had the 3 inch shoes I posted all of the part numbers before but I have no idea how to find it.
Old May 15, 2006 | 09:35 AM
Micaiahfied's Avatar
my srw 350 had 2-1/2 on it.
Old May 15, 2006 | 01:49 PM
edwinsmith's Avatar
My dually had 3 inch wide shoes but only on the right side.
Edwin
Old May 15, 2006 | 03:21 PM
Same here. I have decent drums and will have them turned, but I want to upgrade the wheel cylinders at the same time, just not sure what application to go under for the chevy wheel cylinders
Old May 15, 2006 | 04:23 PM
G1625S's Avatar
I have 3'' shoes. I asked for wheel cylinders for a '94 1 ton chevy P/U at NAPA and they matched the number from the tech facts. Only problem now is that I've lost the right wheel seal twice now. There's no ridge and the seal goes on just fine. Diff is not overfull either. Maybe I need a speedie sleeve for the spindle?
Old May 15, 2006 | 04:35 PM
flashgordon's Avatar
If you can fill the grove that the seal made(durt made) you need a speedy sleve
Have you check the vent toob? The may be pluged and pushing oil out the weekist seal or larges grove.
If the vent toob is plug it will creat a nuff pressure to make a good seal act like it bad.
Old May 15, 2006 | 06:00 PM
G1625S's Avatar
To tell the truth, I totally spaced on checking the vent tube--Thanks!
Old May 15, 2006 | 08:10 PM
I used the Dodge 1 ton dually wheel cylinders. I think that they had 1-1/8" pistons. Pretty good size. I think that the stockers are 1 inch. I'm not sure what size the chevy ones are. Probably the same. I noticed that my pedal was a little bit lower. Took some getting used to but they work really well.
Old May 15, 2006 | 08:23 PM
spunbearing is on the right track, i looked at the chevy and dodge 1 tons, i believe this is correct, dodge smaller is 7/8th and 1 3/16th for the larger. i think the chevy ones i looked at were actually smaller bore than the dodge 1 tons.
PEAKSTRYDE
Oct 11, 2007 04:20 PM
gomerpile
May 3, 2007 09:40 PM
crossy
Dec 2, 2006 11:01 PM
Javaluva
Nov 28, 2002 01:24 PM
