Question about my 46RH
Hello all,
I've had my '93 D250CC for almost 2 months now, and have driven it daily for the past week or so. It has 280K on it and was bought new by a man who pulled his 5th wheel with it. I'm the second owner.
When I put it in D with the brakes on, the tranny makes a clanging/grinding/generally odd sound, but it drives fine, shifts solid, and R works well, too.
My guess is that by 280K it's been rebuilt at least once, but I wonder if maybe I need to adjust the bands or something? I bought it to tow my Jeep with, so keeping the tranny happy is paramount for me.
Thanks in advance for any input available,
Mike
Mike
The flex plate is the piece that would be a flywheel if it were a manual, right? So what kind of wear affects that? I always assumed that it is just a piece to hold the TC to the crankshaft... is there more? I'll be the first to say that I understand nothing about transmissions. And that they scare me, too.
Dodge flex plates are noted for breaking around the crank mounting bolts.
The other issue I have seen and heard of is the engine main thrust bearing going out and letting the flex plate hit the engine to trans adapter.
The torque that these engines put out can take the flex plate out over time.
These were on 903's and NTC350's but the same thing can happen on our baby engines I would bet.
The easy way to check the flex plate is to unbolt the converter and push it back into the trans case. Take a inspection mirror and a flash light and look around the flex plate mounting bolts real good.
So you can do the inspection w/o taking the trans out? That's my primary worry as I don't have a proper jack.
Will I have to take the trans out to change the plate if that's the problem?
Thanks to you both for the info so far...
Mike
Mike
In a shop with a lift and a trans jack this would be a couple of hour job. On a creeper and using floor or bottle jacks add at least 2 to 3 hours. Thats if you have all the hand tools needed.
Wobblin-Goblin
01-18-2007 04:40 PM
GO 4LO
06-10-2005 07:07 PM
