Question about low pressure return lines on injectors
Old Jan 13, 2012 | 11:46 PM
339K&Counting's Avatar
I replaced the injectors on my 92. My son in law helped take out the old ones. I didn't realize how much he had mangled the return line. Now impossible to line up all 6. Tried to bend back into shape.
What is the pressure in these lines? I was thinking of cutting out part of the hard lines and replacing with fuel hose. Would be easy to get banjo bolts screwed in.
My 2003 Sprinter diesel has fuel hose between the return line banjo bolts. Works fine
Think this will work?
I need to get the truck back on the road - I need it Monday
Thanks in advance
Old Jan 14, 2012 | 08:36 AM
Anyone? Weather good today for working outside.
Trying to get truck back on road?
Thanks
Old Jan 14, 2012 | 09:08 AM
hounddogks76's Avatar
can't say on the pressure for sure, couldn't be much . Are ya having problems lining the bolts back up to the holes without cross threading? I had that problem last time i took mine off.
Old Jan 14, 2012 | 09:14 AM
Thanks hounddog
Lining up banjo bolts is the issue. Can get 2 or 3, but not all.
I've tried everything.
Thats why I wanted to put in fuel hose.
Old Jan 14, 2012 | 01:41 PM
texsasdiesel's Avatar
i don't think there would be enough pressure to worry about replacing them w/ a good quality rubber hose rated for diesel, esp if you use some clamps on either end of it. The ford's used to "daisy chain" their returns together w/ rubber hoses as well, they were well known for rotting out and needing replacing tho. I'd say go for it and just carry some extra rubber tubign w/ you just in case something happened while you were on the road. JM2C
James
Old Jan 14, 2012 | 02:36 PM
Thanks James
I'm about to cut - can't get them lined up
Cheers
Jim
Old Jan 14, 2012 | 02:56 PM
j_martin's Avatar
Why?
Old Jan 14, 2012 | 05:10 PM
Moparbubba's Avatar
Vw uses rubber lines on the injector returns on the 1.9 tdi not sure how much pressure a return on a 12mm ve runs tho.
Sent from my DROIDX
Old Jan 14, 2012 | 09:38 PM
Thanks moparbubba,
I cut the lines and installed my fuel lines to connect the back three injectors. Got the banjo bolts installed , bled the system and started the truck. I put clamps on the one line that leaked. Other line didn't leak.
For now I used regular fuel line. Need to route the lines up away from exhaust manifold
Cheers
Jim
Old Jan 14, 2012 | 09:47 PM
bobva's Avatar
I know MB & VW use diesel rated fuel hose.
I think Cummins use's steel for a reason. Im thinking heat!!!!!!!
Old Jan 15, 2012 | 12:40 AM
rebal's Avatar
you can use a good rubber hose and spring clams will be fine I believe that Chevy 6.2/6.5 return line and clamps are real close to that size
Old Jan 15, 2012 | 07:56 AM
Thanks bobva and rebal
My buddy runs a Mercedea shop and he can get me right hose. I added a little extra hose so it arches up (a little) over the exhaust manifold. No dealer had the return line - so I'll see how this solution works.
Cheers,
Jim
t_oad01
Feb 7, 2012 06:42 PM
Rick 12v CTD
Sep 23, 2011 05:21 PM
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
7mmrum
Oct 6, 2005 11:13 AM
