Question for 4x4 Getrags with 3.54s
Old Oct 29, 2009 | 09:25 AM
GLHS's Avatar
I need to get a spedometer drive adapter made and need to know the ratio on the little box conected to the transfer case. Mine was lost.
Thanks,
Kurt
Old Oct 29, 2009 | 01:50 PM
blue92's Avatar
In order to figure mine out I installed my vehicle speed sensor directly to the output from the transfer case. I then drove it with my gps unit and calculated the difference between my speedo and gps. I then found some speedometer ratio adapter on eBay and found one very close. Hope this helps.
Old Oct 30, 2009 | 01:32 AM
Bigone721's Avatar
Your just gonna have to do it like blue92 said, because it will depend on what size tires you have and not just the rear gear ratio. There are also many different sizes of driven gears in the transfer case so you really just need to use a gps.
Old Oct 30, 2009 | 04:36 AM
Chrisreyn's Avatar
Which peice exactly are you needing?
the gear reducer( the 90* box) isnt what determines the ratio, the pinion drive gear inside the tranny/T-case does..
this has info you might find helpfull:
How the speedometer drive works:
https://www.dieseltruckresource.com/....html?t=198123
Old Oct 30, 2009 | 01:58 PM
GLHS's Avatar
I need the gear ratio reducer ( the 90* box).
I know I can hook up the VSS straight to the transfer case; was hoping someone had the part # or could take a quick look at the box to find the ratio. Who knows with a part number might get lucky and find a dealer who still has one on the shelf.
Height wise, my 265/75/16s are the same as the original 235/85/16 tires.
Old Oct 30, 2009 | 02:03 PM
Fred Swanson's Avatar
GLHS, I might have a few of those around, let me look.
avewilson
Mar 28, 2008 05:44 PM
Conn
Nov 26, 2007 04:21 PM
Cowboy_Customs
Apr 11, 2007 11:47 AM
Mark Hodowanec
Feb 27, 2006 07:16 PM
Jambbii
Feb 9, 2004 04:59 PM
