GetragS shifter O-fill procedure
Old Apr 6, 2007 | 05:29 PM
Cowboy_Customs's Avatar
OK, im cheap. I dont want to have to run to town AGAIN today to BUY another part for my truck. And I see there is no deffinative procedure listed to pull the shifter, overfill, and reinstall.
SO, what is the procedure to pull the shifter? Im not feeling adventurous, its cold outside.
Old Apr 7, 2007 | 02:49 AM
A_port93's Avatar
i found it easier to just take out the top pto bolt and just squirt her in from there but thats just my 2 cents.cant help you with the old shifter pull...sorry
Old Apr 7, 2007 | 07:18 PM
edwinsmith's Avatar
Well you have to pull up the big shifter boot and then loosen the clamp to lift the smaller boot up. Then get a set of snap ring pliers and remove the 2" snap ring. Then the shifter should pop out. Pour in oil to your hearts content then find somebody to hold the shifter down while you put the snap ring back in. I'll assume you don't need to be told how to replace the boots.
Edwin
Old Apr 7, 2007 | 08:21 PM
ppiggppenn's Avatar
Another trick is put a small elbow into the filler hole and tilt to where you can fill to about an inch higher, then cap it. I'm not pulling my shifter again if I can help it as the way I reinstalled it took two men and a goat to hold things down to tighten those mickey mouse little screws and monster circlip. Not a tough procedure, just hard work.
Old Apr 8, 2007 | 07:25 AM
MoparMarv's Avatar
I just put a street elbow on mine out of the fill plug. I need to put on about a 3inch piece at a 45 degree angle because with the street elbow I only can get about 4 quarts or so in. I also ran a 1/2 inch clear hose up to the engine bay with a funnel so its easy to fill. when I'm done filling and take off the hose and plug it. Needs a little work but it makes it easy.
Old Apr 8, 2007 | 10:04 AM
BearKiller's Avatar
Lightbulb I Just Might Try This
Originally Posted by MoparMarv
I just put a street elbow on mine out of the fill plug. I also ran a 1/2 inch clear hose up to the engine bay with a funnel so its easy to fill. when I'm done filling and take off the hose and plug it.
Why not install a hose-barb in the street-ell, clamp the clear hose to that, and add a barb with cap at the top end, making the hose a permanent part of the equation??
You could dump in five quarts and mark FULL on the clear hose; or, turn the elbow almost level, dump in four quarts, mark "ADD ONE QUART", then dump in the fifth quart and mark FULL.
Old Apr 11, 2007 | 11:47 AM
I was just thinking of the easy route with a 4-5quart container. Its roomy being 2 wheel drive, but not roomy enough to fit a big jug under there. I want to fabricate some sort of dipstick, that'd be cool. I'm sure I'll come up with something. Thanks guys!
hounddogks76
Jan 14, 2010 01:03 PM
GLHS
Oct 30, 2009 02:03 PM
whiskeyrichard
Mar 3, 2009 12:14 AM
avewilson
Mar 28, 2008 05:44 PM
D-Roc
Feb 1, 2007 04:07 PM
