Pyro/Trans Temp gone, What's Up?
Old Nov 9, 2012 | 01:46 PM
BKTC's Avatar
Fired up the truck yesterday and the trans temp gauge and the pyrometer both quit working. Quick check under the hood didn't reveal anything obvious. Everything else works as normal (tach/boost).
Got any suggestions?
BKTC aka Billy
Old Nov 9, 2012 | 02:26 PM
jstone44720's Avatar
Are they all tapped into the same power source? It may have come loose or blown a fuse.
Old Nov 9, 2012 | 10:23 PM
Ram_SRT-10's Avatar
what kind of gauges are they i know my autometer colbolts i have to unplug the gauge and plug it back in right at the gauge if the truck sits for a week or so
Old Nov 10, 2012 | 04:03 PM
BKTC's Avatar
Autometer..........
The gauges are autometer but I don't remember the series. Black face, red marker (try to look like others).
I checked the ground , Now I'll check the hot hook-up.
Billy
Old Nov 22, 2012 | 03:12 PM
BKTC's Avatar
Still......
Had to bring this back up to the top as the Hot is Good and the Ground is good so What else, bad gauge/gauges ?
Ram_SRT-10, What's up with unplugging gauge ? You mean disconnect the hot side and re-attach?
Thanks, Billy
Old Nov 22, 2012 | 08:54 PM
Ram_SRT-10's Avatar
not sure what style autometer yours are but on my colbolts there is one plug right on the back of the gauge itself unplug that for 5 sec and plug it back in should reset the guage
Old Nov 23, 2012 | 01:32 PM
BKTC's Avatar
Plug?????????
Ram_SRT-10:
Is this plug your power connection? Or is it the lead to your probe?
I'm guessing it's power so your "turning off" power and then reconnecting. YES?
Sorry if I seem a little dense just want to make sure I understand what to do.
Thanks, BKTC
Old Nov 24, 2012 | 08:31 PM
Ram_SRT-10's Avatar
your gauge must be a different model and not have the one single plug on the back of the guage all i can thing to tell you is check and powers and ground
Old Nov 28, 2012 | 04:43 PM
BKTC's Avatar
Any other suggestions?
O.K. I'm still not getting anything on the trans temp or Pyro. The lights on them work when I turn on the lights but the gauges don't register.......
Anybody know if "removing the power" is what Ram_SRT-10 is talking about? If so then what about the trans temp gauge?
Mine don't have a plug. They have a hot, a ground, a light wire and an attachment for the probe.
I just can't believe both gauges went out at once..........
BKTC
Old Nov 28, 2012 | 05:11 PM
Wettstein's Avatar
Have you checked to see if the wire from the prob's to the gauges is good? Are the contacts at the probs good? If you have both wires going through the fire wall at the same place maybe the signal wires got broken by vibrations. Just check continuity between the prob and the gauge. Or check for continuity in the probs. if there is no continuity in the prob then there bad.
Hope this helps
arroyojim
48
Sep 9, 2016 09:43 AM
cbrahs
Nov 1, 2011 11:00 AM
TAMU
May 27, 2009 06:34 PM
TAMU
Apr 27, 2009 11:26 AM
3500Dooly
23
Jun 8, 2006 10:21 PM
