pyro leak
No gaskets.. The fitting you tap into the manifold is NPT (National Pipe Thread) and is a tapered thread. The more you tighten it, the fatter it gets in the hole. No worries about leaks in any of the many I have installed.
If you strip the threads you did not tap it correctly. You should have about 4 turns engagement by hand then turn it maybe 2 more turns to tighten.
Anti-seize is the only thing you should put on it and that is not used as a thread sealant.
Anti-Sieze is a good bet.. I forgot about that, but really its for when you want to take it out. The cast metal in the manifold is nice and soft and should seal.. Most pyros come with brass fittings, I used stainless.
Mine was put in by a guy that I think hadn't done too many. I had a leak and fixed it with furnace cement. Its by the wood burning stove supplies at the hardware store. A little brittle but you get a whole tub for around $3.
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
