Pump timing question
So I am still a ways off from getting a pyrometer; I need to do steering shaft and wheels/tires more urgently, but I am itching to bump the timing a little, if only to see if I can get a little better mileage.
I just ran almost pure biodiesel through the truck for 300 miles of mostly short trip and non-freeway driving and got 16.3 MPG, which I know can be improved on. I have been wanting to try the 1/8" bump, but have been reluctant to without gauges. Is that much timing advance going to:
a) help my mileage at all?
and
b) run any risk of increased EGT related problems?
I have the factory "lagmaster" 21 cm housing, so at least it's not too restrictive. At the rate I'm going now, it will be late summer before I can afford any gauges..
and
As you advance the timing, fuel is injected into the cylinder earlier. This earlier injection means the fuel is being more efficiently used (more completely burned). This leaves less heat energy in the exhaust gases, because more is being used to drive the piston downward. With less heat energy in the exhaust gases, the turbocharger isn't driven as hard, and will take longer to spool up and produce less boost.
Also, you'll see a slight decrease in torque with advanced timing.
Honkylips
Oct 15, 2007 07:07 AM
GR40RCapri
Jun 25, 2006 12:53 AM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
