pump timing off
Old Mar 7, 2007 | 01:28 PM
dodgec68's Avatar
pump timing off
what kind of issues pop up when the injection pump is retarted ot advanced to much?
also when the lift pump starts going?
thanks Jesse
Old Mar 7, 2007 | 04:46 PM
Retarded - white smoke, bad mileage, no power
Advanced - black smoke, loud clatter, hard to start, holey pistons
Bad LP - hard to start, no power, dies under load
Old Mar 7, 2007 | 11:18 PM
dodgec68's Avatar
well when I start it after work it runs rough and blows white smoke until it warms up, does it even worse if you unplug the ksb valve, but after it warms up it seems to run smooth. sounds like a cummins but also sounds like there might be another sound, knocking or ticking under that.
sorry obout all the repetative posts, I just want to figure it out without dumping a whole bunch of money into things that are not broke
Old Mar 7, 2007 | 11:44 PM
ppiggppenn's Avatar
I'd guess some advance would help the white smoke. Mine's black whether cold or pulling hard, none visible otherwise. Oh, my IP timing is stock, or at least untouched by me.
Old Mar 8, 2007 | 06:24 AM
G1625S's Avatar
How recent is your fuel filter? Sounds like timing is back a bit, but I think it may be caused by a fuel restriction to the VE which is limiting the timing piston in the pump from doing its job due to low case pressure. Everybody needs a FP gauge---myself included
Old Mar 8, 2007 | 01:37 PM
dodgec68's Avatar
Yeah I need to put a fuel pressure gauge in it. the fuel firlter is brand new stuck a new one on again when I put the head gasket and push rod in last weekend. am going to try to get a fuel pressure gauge in this weekend and bumb the timing a bit to see if that will solve the problem
thanks
will let you guys know what I find out
ARbowhunter7
Feb 16, 2017 10:14 PM
4969joes
Mar 28, 2010 05:26 PM
West Coast
Mar 26, 2006 11:09 AM
RonP
Feb 24, 2006 02:12 PM
redhornet
May 28, 2004 06:06 PM
