Pre IP fuel Pressure Gauge
Old Apr 4, 2008 | 09:20 PM
CaptainChrysler's Avatar
What size is the pump inlet? 12 or 14mm?
Old Apr 4, 2008 | 10:56 PM
BearKiller's Avatar
Lift-pump inlet, piston or diaphragm, is 1/4NPT.
Injection-pump inlet is 12MM.
Old Apr 5, 2008 | 05:23 AM
Originally Posted by Hot Dawg
I thought they were M12 X 1.5???
Originally Posted by Fishin2Deep4U
This is correct.
Dave
Thanks for the catch, guys.
Old Apr 5, 2008 | 07:58 PM
Alwaysworking's Avatar
alwaysonDTR
i noticed today that on my truck there is a plug in the banjo bolt from the lift pump to the head before the filter does any one else have this?
looks to be 1/8 inch pipe size or so
Old Apr 5, 2008 | 08:14 PM
That's the bleed screw. It's metric.
Old Apr 5, 2008 | 08:17 PM
alwaysonDTR
so if you wanted you could take it out and run a gauge from there? and i figured it was metric but just wanted to give a hint of the size so everyone would know what i was talking about
Old Apr 5, 2008 | 08:53 PM
I went to a local truck shop and bought a new banjo bolt. Drilled and tapped it for 1/8 npt. Doesn't leak. Would have bought one from Geno's, but I was in a hurry, and it's temporary.
Old Apr 6, 2008 | 08:04 AM
You can drill and tap it, but there's not a lot of "meat" left when you do that. The tapped banjos have a thicker head so they are not as fragile.
Old Apr 6, 2008 | 08:34 PM
tomd's Avatar
Good question...
I'm not much of an engineer regarding mechanical gauges.
But from what i'm gathering there must be sending units and other miscellaneous doo-dads that one must connect into the fuel line in order to read pressure.
I should have payed more attention to the fuel pressure gauge I had in my jeep. And that one went to a sw into my dash.
Would be nice to see how to install fuel pressure gauges with either video or pictures.
Getting lost in the details, but still helpfull.
Need to read more.
Regards
Tom
Old Apr 6, 2008 | 11:45 PM
BearKiller's Avatar
Originally Posted by tomd
Good question...
Need to read more.
Regards
Tom
The little metric bleeder bolt that is in the filter-outlet banjo-bolt is tiny, compared to a 1/8NPT fitting, thus standard available gauge fittings are much too large to work.
But, by welding/brazing a standard fitting to the head of the metric bleeder-screw, then drilling a tiny hole through the length of the screw, standard gauge-tubing can then be applied, and the gauge will function.
Or, the bleeder-screw can be discarded, and a standard fitting welded/brazed to the banjo-bolt's head, and the gauge plumbing attached to that.
It is much simpler to just give the seven-bucks for the tapped-banjo-bolt.
Old Apr 7, 2008 | 12:04 AM
alwaysonDTR
that tkes all the fun out
dodgeguy71
17
Jan 19, 2012 12:52 AM
woodrat
Mar 30, 2007 02:05 AM
xp8103
Jan 26, 2005 02:55 PM
Patriot_RAM
Oct 8, 2004 06:10 PM
barracuda
30
Apr 22, 2003 05:55 PM
