posting for a friend of mine
Old Sep 18, 2009 | 09:10 PM
bigragu's Avatar
She has a 93 D250 automatic, that surges in speed every once in a while. I cleaned out the TPS and ran the voltmeter tests and all is good. What would cause it to surge? PS- she has around 4,000 on her atf, and she has an auxilary atf filter. Fluids were changed by me. Let me know
Old Sep 19, 2009 | 05:04 AM
Ramrod90's Avatar
fuel filter???? could be clogged/clogging. Lift pump may be going out. Does it puff smoke when it surges?
Old Sep 19, 2009 | 05:06 AM
jogl's Avatar
My guesses would be:
1) A fuel supply problem; changed filter?, checked lift pump, fuel lines, etc.?
2) A bad IP. On MF tractors with Perkins engines that have CAV IP surging usually means that it is time to have your IP rebuilt because the governor mechanism is getting worn.
JP.
Old Sep 19, 2009 | 04:54 PM
bigragu's Avatar
JP.
Thanks, all. I will tell her about it.
Old Sep 19, 2009 | 06:23 PM
Ramrod90's Avatar
If it ends up not being a lift/filter problem, tell her to put a 3200 spring in and see if it tightens up the governor a bit.
Old Sep 23, 2009 | 10:12 PM
bigragu's Avatar
3200 already in...sorry I failed to mention this. her pump has mild tweaks, afc at highest slant, BD torque converter, gages, all the right stuff to pull a horse trailer.
MTC
May 27, 2014 11:56 PM
ib516
Jun 16, 2009 05:20 PM
jeffs033500
Feb 28, 2007 12:34 PM
TxDiesel007
Feb 7, 2007 07:02 PM
Don M
Jul 10, 2003 08:42 PM
