Possible to back fuel screw out to far
Old Jul 25, 2012 | 12:13 AM
Dean Snow's Avatar
As the title says im wondering if its possible. With the injectors in my sig i have to run my fuel screw out one turn away from the truck being unable to start so i can get near stock settings. I swiched back to a 58/60/16 also as im doing a lot of haulung
Problem is....i will be driving down the road and leave off the pedal and the truck will hold the same rpm and if i shift to neutral it will climb in the rpm range. It doesnt do it all the time. Although about 6 times in 40 miles. Its not the linkage or anything sticking its all free as can be. I can tap the pedal while its doing it and it stays thesame just keeps revving. Only way ive gotten it to stop is if i shove it to 5th gear and lug to around 1000 rpms then it goes away and is fine again.
Also today i put the stock pump top back on with the afc. All is good and free.
My question is....is it possible to have a reverse type runaway. Instead of running it in too far i backed it out too far?
Like i said the truck wouldnt even start or run so i ran the screw one turn further and it fired up. Is that too shallow...or will it hurt anything?
Old Jul 25, 2012 | 11:31 AM
It sounds to me like your throttle lever is indexed too tight. Go one notch looser.
Sent from my Paranoid Android HD2 using Tapatalk 2.
jmd4993
Jun 22, 2013 07:36 AM
JARHEAD
Jun 28, 2011 10:36 AM
92smokin blacky
Feb 23, 2011 07:18 PM
hamilton71801
Dec 20, 2007 12:15 PM
FNJ
Jul 9, 2006 12:45 PM
