Should I Run Far Far Away!
Old Jul 8, 2006 | 03:53 PM
FNJ's Avatar
FNJ
Or should I buy it 93 D 350DRW LE 229364 miles ext cab really badly rotted mason dump body(wich does not work) roof on cab rusted frame dosent look bad. Owner said truck runs good.... but after pulling out dip stick and seeing no oil on it I went back up to the house I ask how much 1500.00 I said Ill think about it. I know i can get it for a1000.00. It has little dings and bangs here and there it needs tires and other things.
Old Jul 8, 2006 | 04:15 PM
funcruise's Avatar
Sounds like you would be buying a lot of work. I would walk and not look back.
Old Jul 8, 2006 | 05:02 PM
bgilbert's Avatar
Sounds good just for parts and if you already have the money. Engine, trans, core support, intercooler, radiator etc well worth $1000-$1500.
Old Jul 8, 2006 | 05:38 PM
NHdodgeman's Avatar
The truck deffinately sounds like a basket case and a half. But as others have noted it would make a great parts veh. If your looking for a working truck to put on the road I would look elsewhere.
Old Jul 8, 2006 | 11:06 PM
DBF's Avatar
DBF
Your first impression is usually the best.
Run.
Far away.
Who knows what shape the higher-priced parts are in? Intercooler could be shot, pump on its way out, etc.
Regards, DBF
Old Jul 8, 2006 | 11:51 PM
runamuk's Avatar
Run, Forrest, Run!!!
Rick
Old Jul 9, 2006 | 12:15 AM
BearKiller's Avatar
Be it auto, or 5-speed??
Did you hear it run??
Engine alone is worth the $1500, if it is rebuildable.
If it is a 5-speed, it is definitely worth the price.
Old Jul 9, 2006 | 12:20 AM
runamuk's Avatar
No oil in the crankcase Again Run Forrest Run!!!
Rick
Old Jul 9, 2006 | 07:17 AM
JD730's Avatar
Just to give you an idea I just bought an 89 cab chassis with a decent mason dump for $300 with no engine. Has the 5 speed in it, frame is not rusted, cab is actually decent. If you decide not to grab it, PM me because I might be looking for another parts truck.
Old Jul 9, 2006 | 09:27 AM
12valve@heart's Avatar
Sounds like a rolling pile of parts. If they are parts that you need, $1K may be a good deal. If you need a truck, fugetaboutit.
Old Jul 9, 2006 | 10:26 AM
crossy's Avatar
It's a parts truck dude. Guaranteed up where you are that the brake lines and fuel lines are on their way out also if the the rest of the truck is that bad. Chances are that the interior is beat.
If you want to work something out on halfers on a grand ,and there are parts you want to keep, let me know. I could use a lot off the front. Have trailer -will travel :-) . might be interested in whole thing if you pass on it. (finders fee always paid)
I humbly disagree that a rebuildable, early , VE pumped, cummins is worth what one member stated when we see complete, good running ones go for that all the time. who knows whats going on inside and engine with low/no oil ? crossy
Old Jul 9, 2006 | 10:50 AM
JD730's Avatar
Right, A member here had a '96 180 hp P-pumped engine with radiator, intercooler, condensor, everthing but the vacum and powersteering pump, still in the frame on the motor mounts for $2000. If I needed it I would have taken it when I picked up the trans from him.
Old Jul 9, 2006 | 11:36 AM
BearKiller's Avatar
It must be a regional thing.
A 1st Gen. will fetch as much around here, as a comparable later engine.
Most, around here, prefer the 1st Gen.
If they are that cheap/plentiful in New Jersey, I need to bring the trailer up there and do some shopping.
Old Jul 9, 2006 | 12:45 PM
JD730's Avatar
Thats the thing, up here you get people who just don't want to be bothered. I paid $1200 for a decent 92 W250 needed brake lines and such, but It starts, runs and goes down the road and stops when I want it too. PO had just done a trans not too long ago, brakes all the way around where put on 2 years ago before the truck was parked.
$800 for a running early 91 W250 out of NY for parts.
$300 for that lastest one an 89 with a mason dump and no engine, 5 speed.
madhat
Dec 1, 2012 10:00 PM
74dart
Feb 9, 2009 08:36 PM
Common
14
Jun 20, 2008 01:46 PM
hamilton71801
Dec 20, 2007 12:15 PM
