tire size
Old Jul 25, 2012 | 02:37 AM
Diesel Jeff's Avatar
tire size
Hi, I have a 91 Dodge D250 Cummins. Can I use LT215/85R/16? I currently have LT235's, but I thought maybe might get better diesel mileage with the 215's. I'm strictly on highway miles. Safety is also important. Any input is welcomed!!! Thanks.
-Jeff[
Old Jul 25, 2012 | 10:10 AM
rrgrassi's Avatar
As I recall a 215 is a bit shorter in height than a 235. Shorter means speedo could read 75, but you are really going 70. That also means less fuel economy.
Old Jul 25, 2012 | 10:39 AM
Jschlachta's Avatar
What rear end ratio do you have, sometime a larger tire diameter will give you better fuel millage and put the engine in a better rpm range. I had a d250 with 265-75/r16 tires and got great fuel economy. that was with a 3.73 rear end. you could also go with something tall and thin liek a 255/85/r16 but tire choices will be limited.
Old Jul 25, 2012 | 10:41 AM
enafzige's Avatar
What is the aspect ratio of your 235s? 75 or 85? What is your gear ratio? What speed do you travel on the highway?
--Eric
Old Jul 25, 2012 | 12:32 PM
simplysmn's Avatar
http://www.miata.net/garage/tirecalc.html here you go try this
oldwhite12v
Mar 25, 2011 04:28 PM
schoust
Oct 21, 2009 10:09 AM
bigdogtruck
18
Nov 21, 2007 08:09 PM
4RnrRick
Feb 27, 2007 11:25 AM
ValkSmile
Jan 23, 2007 11:42 AM
