Please tell me there is a shortcut
Old Sep 16, 2008 | 11:04 PM
  #31
BearKiller's Avatar
Originally Posted by Winr
Remove coolant hoses. Evac Freon, remove insulation pad,blower motor and cover, disconect A/C lines from heater box (and pressure block), remove 6 (+/- 1) nuts that hold the heater box to the fire wall,
Inside truck,
remove glove box door, right kick pannel, heater controll, two screws that hold the air deflector (over the center hump) and deflector, two screws that hold air blend pannel(tucks up under the dash center) and blend pannel, dash brace( near the upper left corner of glove box opening), lower dash attaching bolt (just under the dash, right side kick pannel) and one attaching screw just above accelerator pedal.
Disconect elec conections from heater box, remove vacume lines & gromet from firewall, disconect blend cable (right side of mount under cable gently press tab in and pull cable straight up) remove heater box attaching bolt(under heater box on kick pannel)
Pull dash towords seat enough to let the lower dash mount catch on the door opening
pull heater box away from firewall. lower from under dash while turning firewall side of box towords floor. should slide out.
I got it all apart in a couple hours.
The directions in the FSM were pretty helpful, but they left out a few things. I had to pull the radio out to get access to the vacuum connector, which meant that the dash bezel had to come out. I had to drop my tach and my FP gauge, too. The whole dash is in pieces. The big thing the FSM left out is that you gotta pull out the ABS computer. I spent 20 minutes wiggling the HVAC unit around before I figured it out. I pulled the RWAL computer and the HVAC unit practically fell out.
From the sound of all this, if the wife's ever goes bad, she had just better get used to driving in long-handles and cover-alls.
Before I would go to all that trouble, I would install one of those under-the-seat heater-boxes like J.C.Whitney and the like sell for vehicles that didn't come with heaters; I'm serious, having to evacuate the A/C and gut the insides for a silly heater-core replacement is ridiculous and says little for Chrysler's engineering department.
It takes maybe twenty minutes to completely remove/install the heater-core in either my 1985 Ford or 1978 Chevy; there is no need to even get close to any of the A/C components, and either can be accomplished without draining the radiator, if you are quick and have a couple loops of wire threaded into the hood bracing to suspend the hoses from while you work.
I never imagined it could be such a chore as all this.
Old Sep 16, 2008 | 11:13 PM
  #32
bullfrog5.9's Avatar
my core been broken since the begining of summer but hav to do it soon to cuz it getting cold here in the morns so thanks for doing 1st lol i got good heads up in what is to come lol
maybe ill take pics when i do mine
Old Sep 17, 2008 | 08:09 AM
  #33
BearKiller's Avatar
Here is a nice under-the-dash unit, complete with defrost-ducts :
http://www.jcwhitney.com/DANHARD-UND...8020_10108.jcw
This one could probably be mounted above the dash and concealed in a nice cabinet, as well as being mounted below :
http://www.jcwhitney.com/FLEX-A-LITE...8020_10108.jcw
Another nice one :
http://www.jcwhitney.com/Heaters/GP_...8020_10108.jcw
These are just a few of the many units available, any one of them probably pushing more hot air than the factory system.
Besides a new heater-core, they have a SEPERATE new blower-motor/fan, and a seperate new switch.
I fully intend to go this route, if and whenever the core goes bad in any of my Dodge fleet.
I have no idea just what I would be getting into on the Son's truck, as it is a non-A/C cab, with a hidden, behind-the-dash, after-market A/C system that is completely independent of the heater system, even having a seperate blower, all tucked in somewhere inside the dash; this system does share the non-A/C heater-control-panel, with some weird leaf-spring switches that turn on and off the A/C functions, and the fan-speed switch "switches" to whichever system has been selected, turning on one blower or the other; there is a whole herd of relays connected to this mess.
No one has yet been able to tell me just what brand this unit might be, so that I can contact them and get an instruction manual and parts listing, should I ever need to replace any of this.
Old Sep 17, 2008 | 10:58 AM
  #34
Bob Beauchaine's Avatar
Not an egg - the white of an egg. BTW it works.
Bob
Old Sep 17, 2008 | 12:35 PM
  #35
leadvilleram's Avatar
Good tip for emergencies...I wonder how many vehicles are out there with eggs in thier cooling systems. Maybe toss in some bacon too!
Old Sep 17, 2008 | 03:16 PM
  #36
Richie O's Avatar
366 Spring Chicken
My grandfather used both pepper and eggs in his radiator when he was around. He had a 78 gmc and I saw him dump both in over the years. ( he also used to defrost his windshield with a pot of hot water off the stove ) Never once broke.
Old Sep 17, 2008 | 05:23 PM
  #37
Originally Posted by leadvilleram
Were you able to fully disassemble and reassemble without refrigerant evac, or is that a mandatory step? My AC doesn't work anyways.
I need to tackle this one before winter (which will probably be in about 3 weeks).
The A/C does need to be dumped, no way around it.
Old Sep 17, 2008 | 05:27 PM
  #38
Jeez, it really isn't that bad. Maybe 6 hours work total. You'll put way more time than that into transplanting some other system. And it's not like the darn things spring a leak on a regular basis, this is a once in 10-15 year kind of job. Most folks won't do it twice on the same truck.
Old Sep 17, 2008 | 06:45 PM
  #39
ofcmarc's Avatar
Jeez, it really isn't that bad.....And it's not like the darn things spring a leak on a regular basis, this is a once in 10-15 year kind of job. Most folks won't do it twice on the same truck.
I've owned 6 1st gen body style trucks anywhere from a 1975 to a 1993 and only had to do 1 heater core. It was a non-a/c in a 1/2 ton gasser and it took 4 hours in the pouring rain. (didn't have time to wait for better weather. It was already October ) That was the first time. Next time (if ther is one) will probly be faster.
I wouldn't let Mama freeze. If Mama ain't happy...... I know what's good for me.
Old Sep 17, 2008 | 08:57 PM
  #40
Yup, I agree. Thanks for the AC info as well. I'll just have a local shop evac that stuff, if there's any left. This is gonna be fun! If I have the patience, pictures will be taken.The Toyota was about a 3 hour job, only to find out the core was fine....air bubble in the system.
Old Sep 17, 2008 | 09:31 PM
  #41
rockfoot's Avatar
Yea.. I did mine a few years ago... I didn't even think about how long it was gonna take, I just bit the bullet and dove in... takin' stuff apart.... It really wasn't that bad... after it was done!
Old Sep 18, 2008 | 05:23 AM
  #42
Jim Lane's Avatar
Post
Required:
Patience,
One Afternoon,
Box of Band Aids.
I replaced mine a few years ago and I probably spent most of the day on it. I have all of my own AC equipment so after I was finished I simply recharged it.
I took my time and removed the dash and got to the heater. It was a bigger pain getting the insulated cover off the motor and to get to the bottom bolts on the box that are under the blower motor.
It is a good idea to take digital pictures of it as you remove it and take it apart because there always seems to be 2 ways that part fits back it there and the wrong way was always your first choice.
When you have the box out and split it open pay attention to the Blend Doors that are inside the box that redirect the air out the outlets, there are foam rubber seals that seal the doors to the housing that you might need to make replacements for.
Also after I got the core installed and before I put it back into the truck I put a pressure test on the core to make sure it was not leaking from a poor solder joint.
When the heater was out of the truck I took this time to clean out the maze of ducts by carefully stuffing a rag wet with Windex through them, inside one side and pulling it through until they were clean, and then I cleared them out with compressed air.
If you happen to park where there are a lot of trees, now would be the time to cut an opening into the air box so you can be able to access the front of the evaporator when it is time to clean it out.
Also drain and reverse flush your cooling system and start with fresh clean coolant.
Now would be the perfect time to install a coolant filter.
When you reinstall the H-Valve to the evaporator make sure to use NEW Crush Gaskets and O-rings.
When you are finished, get under the truck and make sure the evaporator drain tube is not pinched or blocked.
Jim
Old Sep 21, 2008 | 11:04 AM
  #43
Well, i got through it ! Heat that doesn't smell like coolant is great! My wife noticed right away. She is sensitive to any odd smells, so that's a huge improvement. Maybe she'll come out and help get firewood with me now...
I replaced the radiator, hoses, coolant and belt while I was at it. That all took the better part of 2 days (alot of that time was wrestling with the radiator shroud)Once I got it in the right spot, it was a piece of cake. Now I know.
Also found a spot to engage a 3/8 ratchet in the belt tensioner...that tip should be somewhere in the stickies for a newbie such as myself. I just found it by assuming(hoping) an engineer had designed some sort of way to disengage that thing without taking a BFH to it.
Now to figure out what that tick is. I read on a few threads that people report a tick coming from the lift pump actuator that follows the cam. Any aftermarket pumps out there that are electric or improved design?
Old Sep 22, 2008 | 08:18 AM
  #44
apwatson50's Avatar
Just run some biodiesel, as soon as I did, the tick went away completely. Also I didn't get the tick until I added my oversize dual filter setup. This is with the piston LP.
But bio did the trick for me.
hamilton71801
Jan 9, 2008 09:37 AM
96RAM
15
Mar 27, 2006 03:58 PM
BigBully
Sep 29, 2005 12:27 AM
Ian
Mar 13, 2005 10:31 PM
Corwin
Jan 16, 2005 11:06 PM
