There is Still Alot there, Please help me Find it
Old Sep 24, 2005 | 08:57 PM
BigBully's Avatar
The Fummins is one fun truck but I need More Power. Do I need to Upgrade to a Bigger Turbo housing first? The one there is What, a 3 inch? and I need a 4 inch? Correct? I havent Ground the Foot yet or done the fuel pin but I have been running 50/50 Meth/water and its a Kick in the butt. In That video I was just running Windshield wiper Fluid and its not much of a kick.
Old Sep 24, 2005 | 09:07 PM
You can replace the hybrid turbo with an HX-40 or an HTB2, that will get you a 4" outlet. If you can't control the EGT with the hybrid, you need a bigger turbo before you add more fuel.
Old Sep 24, 2005 | 11:34 PM
BigBully's Avatar
Its not too bad with the Water but still hits 1400 fairly easy
Old Sep 25, 2005 | 06:38 AM
Oh, is that all?
You could grind the AFC lever, but doesn't Colorado make you do a smog test? A truck with a ground lever doesn't have a prayer of passing. Go over to the Diesel Central board and get in touch with KTACummins. He has had a few 14mm pump heads made up, he may still have some left. He's well over 500 HP on straight #2.
Old Sep 25, 2005 | 10:22 AM
BigBully's Avatar
Some of Colorado But not where I live. Shoot 1400 is great considering it used to Peg the pyro
Old Sep 27, 2005 | 02:59 PM
BigBully's Avatar
can someone give me details on Grinding the Pin? I was gonna buy the BullyDog pin but if I can do it myself (safely) I would rather save the cash.
Old Sep 27, 2005 | 03:03 PM
As long as you don't grind the stock pin so much that it breaks, you can't hurt anything. Just make the deep part as deep as you think you can without weakening the pin too much. Leave the big end alone. A ground stock pin will not cause a leak.
Old Sep 27, 2005 | 03:36 PM
BigBully's Avatar
ok I think I under stand but is it just like the last 1/8 inch of travel that I am after? Does it need to be Polished so it wont wear?
Old Sep 27, 2005 | 03:38 PM
Yeah, you just want to make the deepest part as deep as you can, but keep a smooth curve going down into it. You want a nice finish like what's there now when you are done.
Old Sep 27, 2005 | 07:37 PM
BigBully's Avatar
So how do i make the Finnish Smooth like that. If I get my Grinder out that thing will look like a dog chewed on it
Old Sep 27, 2005 | 08:37 PM
kcprecision's Avatar
A dremual tool and some emery cloth and start polishing. Maybe use a 120 grit to start and move to 300 grit. As I have never done what you are wanting to do what I am suggesting may not work in your case.
Old Sep 28, 2005 | 04:33 PM
Yup. Gonna have to polish it.
Old Sep 29, 2005 | 12:27 AM
Bushy's Avatar
Patron Saint of 1st gens
I actually had really good luck using my dremel tool as well...when the "grind" was done, I used one of the included "felt" polishing wheels and some polishing compound....darn thing came out looking like buffed chrome....worked real good...go for it...
bob...
DodgeRamdiese01
Aug 3, 2009 11:01 PM
quick1sr
May 1, 2009 06:26 AM
goffracing
Mar 29, 2008 12:13 AM
crash4wd
Dec 17, 2007 08:48 PM
erinestes
Jun 3, 2003 10:09 AM
