Please Help!!!!!
Old May 24, 2005 | 07:28 PM
  #31
fearthedeere's Avatar
Where is it at??
Old May 24, 2005 | 11:07 PM
  #32
sammy340's Avatar
I think my thermostat is kinda screwed up. It cycles from 1/4 to the middle gauge quite a bit. Is this normal or should it just stay in one spot?
thanks
Old May 24, 2005 | 11:21 PM
  #33
edwinsmith's Avatar
That kind of sounds flakey. Mine comes up 3 ticks and stays there. If I was hauling a big load it would probably go up but haven't done that yet. Every vehicle I've had is very stable on the temp under light loads.
Edwin
Old May 24, 2005 | 11:34 PM
  #34
sammy340's Avatar
edwin,
i think i'm gonna have to replace mine then
Old May 25, 2005 | 08:16 AM
  #35
92DIESEL's Avatar
my temp gauge goes up to the first line in the middle and then settles down about a 1/4" toward cool- from what I've been told this is normal
Old May 25, 2005 | 04:37 PM
  #36
Originally posted by fearthedeere
Where is it at??
2 wires go down to the starter, follow the small one. There should be power to it when you try to crank the truck.
Hey Monty, maybe you can break the starter problem out of this thread?
Old May 26, 2005 | 06:13 PM
  #37
sho_shane's Avatar
Its ok I know im not inportant
No I think Ill just have to deal with the smoke. It only does it for the 1st 10mins or so then it seems to run ok.
Can I ask one more Q if its ok.
After my truck warms up and the lite smoke goes away, When I get on my truck it still throws out a Dark Gray to a lite black smoke is this normal? thanks for any help and Thanks for all the help yall have given already...
Old May 26, 2005 | 06:19 PM
  #38
Did you run through the KSB diagnostics I linked to in my earlier post? What was the result? It's likely that your problem is a bad connection or a bad KSB switch.
Does the black/gray smoke pretty much clear out once the turbo spools up? If so that sounds normal.
Old May 26, 2005 | 09:06 PM
  #39
sho_shane's Avatar
Ya te smoke clears when the turbo spools
Old May 26, 2005 | 11:57 PM
  #40
Bushy's Avatar
Patron Saint of 1st gens
After warm up the smoke will depend on your fueling/boost levels....if you have fueling come on a bit too early then the smoke will tend to be more toward the black or dark grey.
If you have the pump set "properly" then the fueling "increase rate" will be slow enough that the boost will be up before you get any extra fueling and your smoke will lean more toward the grey side.
Normally a grey color means you have your fueling per lb. of boost set about right.
pb....
Old May 27, 2005 | 04:07 AM
  #41
sho_shane's Avatar
Thanks buddy
jamesbfishin
Apr 16, 2016 11:32 AM
DHT
Apr 2, 2010 07:12 AM
SuperiorRam
Mar 15, 2007 03:10 AM
MoparRiggan
Jan 17, 2006 12:43 PM
Lary Ellis (Top)
May 21, 2003 10:16 AM
