Please Help!!!!!
Old May 23, 2005 | 11:04 PM
edwinsmith's Avatar
Check your thermostat. Does your temp gauge come up to normal? If your thermostat is stuck open it won't come up to proper operating temp and everything will suffer. $$$
Edwin
Old May 23, 2005 | 11:06 PM
sho_shane's Avatar
Where is the thermostat Housing and ill put a new one in it tommarow?
Old May 23, 2005 | 11:12 PM
edwinsmith's Avatar
It's at the front of the engine. It goes in sideways from the passenger side. Take off the hose and the fan belt I think has to come off since you have to drop the alternator down to get one of the bolts out. Be sure to get the thick rubber gasket when you get the thermostat.
Edwin
Old May 23, 2005 | 11:15 PM
sho_shane's Avatar
ok ill check it out in the morning and thanks could that be whats making my truck smoke like it is?
Old May 24, 2005 | 08:22 AM
sho_shane's Avatar
If I unpluged the right thing then with the KSB I mean then the smoke didnt get any worse it just stayed the same
Can some one please post a pic of the KSB with an arrow pointing to the KSB Thanks
Old May 24, 2005 | 08:27 AM
sho_shane's Avatar
This smoke is really bothering me
Old May 24, 2005 | 08:34 AM
sho_shane's Avatar
Today im going to change the oil, put a new tranny filter and new pan gasgit, new air filter, and a new thermastat in it...
Old May 24, 2005 | 03:35 PM
edwinsmith's Avatar
The KSB solenoid is on the left side of the VE inj pump and is attached at an angle with a wire clipped on the back end and a metal tube on the front end. It is a slow acting wax pellet solenoid so simply disconnecting/connecting for a few minutes may not show any difference.
Yes, running cold will cause more smoke and sometimes missing. The KSB will advance the timing when it's cold and you should notice the engine "ping" is more pronounced when it's cold. It should go away when it warms up.
Does your temp gauge come up when it's warmed up? When I got my truck the thermostat had been gutted so it didn't warm up at all. It smoked more and ran crappy until I put a good thermostat in.
Hope this helps.
https://www.dieseltruckresource.com/...m=161&pid=1231
Edwin
Old May 24, 2005 | 03:41 PM
Originally posted by fearthedeere
Hey dave sorry to steal the thread sho but my kbs came of tonite and the truck wouldnt start, i thought my battire was dead so i popped the hood and there it was just hangin there, i also noticed a ton more smoke on the way home and played a lot more but does that sound right that the kbs causes the truck not to start?
I think you confused the shutoff solenoid with the KSB. Shutdown is on top, if it doesn't have power the truck will not start. KSB is on the side, has a tube coming out one end of it. The truck may smoke when cold if it doesn't have power.
Old May 24, 2005 | 03:49 PM
KSB threads-
https://www.dieseltruckresource.com/...threadid=57187
https://www.dieseltruckresource.com/...threadid=58928
KSB stands for "KaltStartBeschleuniger". If your German is not so good that basically means cold start advance.
Old May 24, 2005 | 04:40 PM
fearthedeere's Avatar
Dave the kbs was undone and as soon as i plugged it back in she fired right up.
Old May 24, 2005 | 04:43 PM
That's weird. Unplugging the KSB shouldn't keep the truck from firing, even if it's really cold out.
Wouldn't crank or wouldn't fire?
Old May 24, 2005 | 05:01 PM
wouldnt crank
Old May 24, 2005 | 05:26 PM
k now im ticked, it wont start again and the kbs in pluged in, so i think it was a fluke that it started yesterday after i plugged in it. Anyone got a grenade i can borrow??
Old May 24, 2005 | 05:42 PM
Get a test light and see if you're getting power to the starter solenoid when you hit the key. If you have power there, most likely it's the contacts in the solenoid - they are the most common cause of starting troubles after corroded battery connections.
