Confused
Old Jan 15, 2005 | 08:46 PM
fearthedeere's Avatar
Confused
Ive changed my fuel filter and still the engin runs ruff and misses out when i start it up. and tons of white smoke pours out. i dont kno what to do now. also how hard is a clutch to replace. im a beginner and have hardly no wrench experience yet.
Old Jan 15, 2005 | 08:52 PM
Does it do this even with a warm engine? If it only does it cold then the KSB system is not working.
Old Jan 15, 2005 | 08:59 PM
Den's Avatar
Den
Link to KSB thread
Den
Old Jan 15, 2005 | 09:37 PM
Great another step backwards. How do i fix this
Old Jan 15, 2005 | 09:44 PM
You should have power to the KSB switch any time the key is on, power actually comes off the shutoff solenoid. If you don't have power after the KSB switch and the intake temp is below 90 degrees, the switch is bad. If you have power at the KSB solenoid at the pump, follow the directions in the thread for testing the solenoid.
Old Jan 16, 2005 | 08:53 PM
K i put my truck in the garage and she started up no white smoke. she still almost died after i reved her up but thats usual. when i trun on the key there is a click and a hum then a click. whats that.
Old Jan 16, 2005 | 10:10 PM
ARedetzke's Avatar
Your grid heaters cycling. It's normal
Old Jan 16, 2005 | 10:29 PM
Den's Avatar
Den
There is an intake heater. The 2 relays are located on the inner fender on the drivers side. This kicks on when intake air is 59F or below. It's the wait to start function and after starting it continues to cycle until the intake air is above 59F.
The ksb soleniod is below the injector pump and is powered while the air temp is below 90. When the engine is cold, there should be voltage to the KSB solenoid soleniod. The enigine will also have a different sound to it while the KSB solenoid is energized.
Den
Old Jan 17, 2005 | 03:21 PM
k i tested the kbs solenoid plug on the pump and there was no readin and then i pulled the plug on the air tem /ksb and got a reading
what do i do now
Old Jan 17, 2005 | 05:39 PM
If the engine is cold and you're not gettin power at the KSB, but there's power to the switch, then the switch or the wiring is bad. Check the resistance in the harness between the switch and the solenoid. It should be less than 10 ohms. If that is OK, then the switch is bad.
James2
Aug 1, 2003 09:05 AM
wheels
Jun 7, 2003 07:52 AM
w4xtc
Apr 30, 2003 01:03 PM
Rigg4x4
Apr 10, 2003 07:17 PM
The Boss Hog
Dec 20, 2002 05:03 PM
