Piston LP spring
Old Jun 29, 2010 | 10:25 AM
apwatson50's Avatar
Piston LP spring
Does anyone have a low pressure piston lift pump spring handy? I want to verify the spring rate of the spring.
I'm trying to find a spring that I can put in my HP 2nd gen pump to give ~15-20 psi. As the low pressure spring in the 2nd gen pump only gives ~10psi.
Thanks!
Old Jun 29, 2010 | 12:10 PM
jimbo486's Avatar
BC847 can more than likely answer that question as he's disassembled both low pressure and high pressure pumps. the info you're looking for could very well be in the sticky article he wrote when comparing the 2 pumps.
Old Jul 1, 2010 | 11:41 AM
apwatson50's Avatar
I've already looked in that thread and he doesn't have that specific info. I have the high pressure spring spec'd, and I have the low pressure spring in the pump on the truck right now. Really I just don't want to take the spring out to measure it, but I guess I will.
I think i've got a spring picked out, but I don't want to order it until I verify that its between the low pressure and high pressure. Right now i'm only getting 10psi with the low pressure spring in the big 2nd gen pump.
Old Jul 1, 2010 | 02:26 PM
jimbo486's Avatar
there's a good chance BC847 might have measured the 2 springs. shoot him a PM, i'm sure he could help you out in some way.
Old Jul 2, 2010 | 09:27 AM
apwatson50's Avatar
i'll send him a message and see. If not i'll just have to pull the other spring out and put it in the press and measure it.
sinthome
Oct 17, 2013 06:57 PM
justagoodolboy
Apr 23, 2009 03:49 PM
PeytonMaterne
Aug 11, 2008 10:00 AM
Txwelder
Feb 27, 2008 01:03 PM
CTD99
13
Aug 23, 2005 10:55 PM
