Piston lift pump problem
Old Jan 24, 2011 | 05:51 PM
TRENDZ's Avatar
My truck has been starting very hard lately. Very long crank time before starting. Runs bad when it does start until its running awhile. I figured it had an air leak in the fuel system. I go to pump the lift pump, and drip drip drip. The lift pump primer bellows is leaking. Are any parts available for these pumps or do I need a new one? (high pressure piston pump)
Old Jan 24, 2011 | 05:56 PM
BearKiller's Avatar
It's most likely just an O-ring; it won't hurt anything to experiment with re-sealing it, seeing as how the only other option is a new one anyway.
Old Jan 24, 2011 | 06:53 PM
If it's leaking out of the little rubber tube on the back of the AFC, then your O-ring on the small fuel pin is shot. You will need to pull the AFC to replace it. You can get a complete re-seal kit from Bosch under part # DGK-121, I believe.
Old Jan 25, 2011 | 02:26 PM
B-North's Avatar
He said lift pump
PapeCAT
Dec 9, 2017 03:23 PM
GIT-R-DONE
Aug 24, 2011 10:27 PM
smalltownram
Mar 25, 2010 07:48 PM
BurrisWill
May 29, 2009 12:58 AM
CTD99
13
Aug 23, 2005 10:55 PM
