problem after piston lift pump install
Old Mar 25, 2010 | 04:01 PM
smalltownram's Avatar
i just put a new piston lift pump in my 89 non ic and now it struggles to start up but it is fine after it starts anyone have this problem thank
Old Mar 25, 2010 | 04:06 PM
apwatson50's Avatar
air leak somewhere
Old Mar 25, 2010 | 04:44 PM
but i have good pressure after it starts is there any way to test for air leaks
Old Mar 25, 2010 | 05:00 PM
ofcmarc's Avatar
Just double check all the connections you made when putting on the new pump. The LP outlet on mine took some patience to get it to quit leaking..... Once you're running, the piston LP flows enough that you won't see a pressure loss unless the leak is HUGE.
Old Mar 25, 2010 | 07:48 PM
Pressurize the fuel tank, that will show leaks in the supply side. Only put 3-4 psi in there though.
BC847
Apr 29, 2019 10:35 PM
Bruce M
Apr 17, 2014 02:50 PM
stillsmokin209
Apr 13, 2011 09:31 AM
TRENDZ
Jan 25, 2011 02:26 PM
CTD99
13
Aug 23, 2005 10:55 PM
