piston lift pump?
piston lift pump?
Hey guys, I am replacing my lift pump, and just wondering if i would benefit at all from a piston pump? my mods are in my sig, and i will have a water/meth system in tomorrow as well as a Gilette diesel stage 3 kit in about a month (i know these have nothing to do with fuel) should i go to a piston pump setup?
thanks.
thanks.
My own opinion is that any truck /owner will benefit from a piston-lift-pump.
When you swap pumps, also replace all the hard lines and banjo bolts with 3/8 flexible lines, tees, and fuel pressure gauge fittings.
With flexible lines, fuel-pump R-&-R becomes an act in simplicity.
The bully dog fuel pin is soft and can get a grove worn in it in a short time and start to stick. Keep an eye on it. I have seen it on the 2 of them I have messed with. Now I run the "DennyT Power Pin" That a friend of mine makes ( also a member on here ). Its very hard SS and we have played with a few diff fueling curves.
