piston lift pump
Go to the tech articles. scan down toward the bottom. There is a section on the piston lift pump. It has part numbers and everything you need.
If you have put bigger nozzles in and start turning your fuel screw in, I would say its time for the piston pump.
Good luck.
Good luck.
I made 332 HP with a stocker, I guess the question is, At that HP how long will the injection pump last. The issue is, Our little injection pumps rely on fuel to keep it cool. You may make 400 HP with a stock lift pump but how long will it last. We want power as well as reliablity.
If you can afford $200 go for the upgrade and you will have no worrries about the fuel system.
