pin grinding
Old Apr 27, 2007 | 09:34 AM
93beater's Avatar
pin grinding
how do you grin your fuel pin, and how hard is it to do, im sure i have all the tools just need a little guidence, also what is the plastic washer every1 is saying to shave, is it the off white plastic one that goes in under the fuel pin?
Old Apr 27, 2007 | 12:11 PM
93beater's Avatar
a little help please im craivng the power and info.
Old Apr 27, 2007 | 12:15 PM
G1625S's Avatar
Here's mine and a stocker for comparison. Mine is actually too deep, but something in that neighborhood will work. I don't see the point in shaving the washer...I just cut the cone deeper sooner
Old Apr 27, 2007 | 02:38 PM
gomerpile's Avatar
what do you mean by too deep, and would this make any egt problem, being the only thing on the pump modded was the pin turned
Old Apr 28, 2007 | 09:18 PM
bgilbert's Avatar
Too deep can cause the fuel pin, not the cone which is the piece that you grind, the fuel pin is what pops out and rides against the ground cone... can cause it to pop out too far and cause the o-ring that is around it to leak, filling your AFC top/housing with diesel fuel and leak out the vent.
Old Apr 29, 2007 | 07:40 AM
G1625S's Avatar
Exactly Funny thing is, mine doesn't leak. When I had the pump top off last, I pushed the cone to the bottom and pushed the pin in via the AFC linkage and it bottomed out well before the profile of my cone contacted the pin.
Old Apr 29, 2007 | 11:29 PM
93beater's Avatar
seems pretty simpile, im good w/ my hands and have all the tools needed, should i give it a shot!
Old May 2, 2007 | 12:51 PM
93beater's Avatar
does any1 else have nay pictures or how they did there pin, or some tips! thanks
Old May 3, 2007 | 02:16 AM
bgilbert's Avatar
Just find a pic of the high dollar cone and copy. I use a die grinder, you can also use a dremel tool.
Old May 3, 2007 | 09:42 AM
93beater's Avatar
ok ill search for a pic of the old smokey, and ill use my dremel! thanks
Old May 5, 2007 | 10:50 PM
93beater's Avatar
does anyone happen to have a flick of there old smokey fuel in or one like it, i want some example b4 i cut into mine
Old May 6, 2007 | 07:02 AM
gomerpile's Avatar
go onto a site like bullydog.com and look for the power pin under mech performance and there is a pic of theres, like the old smokey just a copy.
Old May 6, 2007 | 11:07 AM
XLR8R's Avatar
Wow - that fuel pin got a bit too skinny, huh?
Old May 6, 2007 | 01:24 PM
93beater's Avatar
super ez, im goina do it! ill post some pics maybe do a write up!? who knows?
Cowboy_Customs
Oct 18, 2011 01:46 AM
93Fury
Sep 18, 2007 08:46 PM
np205
Feb 7, 2007 10:55 AM
mhuppertz
Jun 7, 2005 05:13 PM
cLAYH
Feb 6, 2004 10:59 AM
