Pass. door lock only works with door handle!
Old Mar 22, 2016 | 01:17 PM
dparker's Avatar
My passenger door lock only operates correctly when the outside handle button is depressed. I have power locks and the unlock function works correctly, but I can only lock the door if I depress the outside handle and push the lock down at the same time. Manually locking the door this way is getting old.
Is this correct??
Is there any way to change this function?
Thanks
Old Mar 22, 2016 | 02:37 PM
Are your front doors 1977 vintage? If so then it might be just the way they were designed to function. My late 60's and early 70's mopars all had the same function, depress drivers outside door button, then lock the inside button and hold the the outside button until the door was latched. A mechanical safety feature so you were less likely to lock you keys in the vehicle.
Perhaps getting door latch mechanisms from a 90's truck would probably give you the function you desire.
Old Mar 22, 2016 | 03:14 PM
dparker's Avatar
Front doors are '92 I believe. Definitely early 90's.
Old Mar 22, 2016 | 03:38 PM
Have the door latch mechanisms been removed, cleaned of all the old dried up grease, then re-lubed liberally with spray on white lithium?
Old Mar 22, 2016 | 04:26 PM
dparker's Avatar
They have been. Was hoping for something simple that I missed, like the child safety switch on new vehicles rear doors.
800rmk
Apr 5, 2009 08:09 PM
xp8103
Jun 2, 2006 07:00 AM
hemertwv
Sep 16, 2005 12:12 PM
IntakeRacing
Jan 9, 2005 06:27 PM
7mmrum
Nov 11, 2004 07:08 AM
