power door lock button only locks 3 doors
On my 04.5 my power door lock button only locks 3 of 4 doors. The rear drivers door will not lock or open with the open. Anyone have any insight for me?
https://www.dieseltruckresource.com/...ad.php?t=87151
Im not sure if this will help you or not. But try reading this old thread and look closely at post #15 (Stew130's post) about how to replace the door lock solenoid. Jonesey in post #23 lists some part numbers. It worked for me replacing my driver door solenoid. Hope that helps.
Same thing happened with mine. After buying a new lock solenoid (that didn't fix it) I started doing continuity test to narrow down the location of the problem. It was just as Nick says above. One of the wires runnin through that fore mentioned 'rubber boot' looked as though it had been cut. Check that out before you buy another solenoid. Yes, my old solenoid was still good. Good luck.
RowJ
Jul 10, 2011 01:26 PM
cLAYH
Dec 14, 2008 04:57 PM
can17
Nov 10, 2008 02:53 PM
nomad65
Aug 20, 2007 06:01 PM
LanceK
May 17, 2007 01:54 PM
