P-Pumped conversion
Old Nov 10, 2006 | 09:00 AM
Mcmopar's Avatar
P-Pumped conversion
OK guys,
I have a 1975 Dodge crewcab that I want to put a P-pumped CTD into, I have a donor first gen for some parts. Motor mounts, rad support, etc. When done it will be going the E-bay way!! My big question right now is---How do I get the pump to clear the brake booster/master cylinder??
Old Nov 10, 2006 | 06:33 PM
Use a smaller booster or score a hydroboost setup off a later 2nd gen.
Old Nov 11, 2006 | 01:05 AM
bgilbert's Avatar
The master cylinder is not an issue with a 1st gen p-pump truck. It will clear.
Old Nov 11, 2006 | 07:52 AM
tboling's Avatar
Thumbs up
It will clear, But it is close! U will like the out come.
Old Nov 11, 2006 | 09:31 PM
frostie's Avatar
I believe the clearance problem will be with your fuel filter. not the injection pump. The filter can be relocated.
Old Nov 11, 2006 | 09:57 PM
iker42's Avatar
warning, once you p-pump, Wannadiesel will never speak to you again out of extreme jealously....
Lol
Mike
Old Nov 11, 2006 | 10:12 PM
Forrest Nearing's Avatar
use a hydraboost unit for the brakes... and ditch the OEM heater/filter/etc. and go w/ a FASS... not that you need to, but that stuff is so cluttered!!!! that's high on my list for my truck
Old Nov 13, 2006 | 09:13 AM
Mcmopar's Avatar
I will, right now I can pull the FP down to 20-22 ish on my 12valve, the one going into the 75 will be MUCH more radical!!
DieselDaze
Jul 6, 2004 05:48 PM
dodgeram
Jan 3, 2004 07:45 AM
dodgeman01
20
Aug 31, 2003 09:42 PM
McGyver
Nov 29, 2002 10:18 PM
