Old Smokey Mount
Old Smokey Mount
I printed the detailed drawings for the OSM off of the stickys and took them to several metal shops around here, and after I recovered from sticker shock, $125 - $155
for 14 gauge metal, I was wondering where you guys that have them got them and how much they cost?
I made mine at work out of 18ga steel. there is NO WAY it should cost more than 50 bucks! And thats including metal! If its because of the bends is why it costs so much, cut and weld it together to save if you have access to a welder. It took me maybe 1/2 hr tops to make my mount. And i did bend mine. very simple.
hope it helps.
ez
hope it helps.
ez
I picked up the heaviest gauge metal i could cut by hand from Tractor Supply, used a pair of tin-shears to make the cuts and made teh bends over the edge of my work bench..mounted it using self-tapping screws.
Think I have about $18 invested in it....
I need to paint it, but its working fine for over a year now.......
i had some free diamond plate. i cut it myself and including the 5inch hole with a hole saw. i had them bent, (2 of them) i believe i paid $25-35 to have them bent, they wanted $50 to cut the holes.
The only problem I have with mine is that it is flexible enough that the bottom edge is scratching the inner fender well..
Mine i made from a link to this website of a pic of a cardboard template. It is not mounted with any screws and it stays put perfectly! Did have to take out the coolant bottle and move the AC drier to get it in place, reinstalled them and works fine.
I found a piece of scrap metal laying around, cut it with a cutoff wheel, and bent it over the workbench... I even cut the hole with a cutoff wheel because we don't have a big enough holesaw.
I hope my advice helped. Oh yeah, keep in mind that all metal, I mean all kinds, stainless, copper, galvanized, etc. is overly expensive anymore, due to the war. Expect at least $50.00 for a hunk of steel for the BHAF box dimensions.
I was going to use 16ga but we didnot have any scrap of it at work and i thought pulling out a new sheet was a little conspicuous! haha 18ga works great in my opinion. Bead rolls would look awesome on ole' smokey mount!
