oil on turbo...pics
oil on turbo...pics
take a look at these pictures and let me know if my turbo should look like this. I am mainly worried about the oil I see here. there was also some oil in the intercooler lines.
Notice the oil around the outside of the compressor wheel here:
and notice the oil around the compressor housing inlet here:
Let me know what you think. I cannot figure out where this oil could have come from.
Thanks,
Russ
Thanks,
Russ
Oh, and the missing pieces of the compressor wheel in your pictures is for balancing purposes.
the sealing ring is that rubber gasket that the compressor housing seats against right?
I can try replacing that.
I did not check to see if the drain was plugged. Good thought. I'll go check that out.
Thanks,
Russ
Thanks,
Russ
Sounds like the center section is about to come apart. This is where your bearings, seals, shims, ect. are. If you are putting out enough oil to oil the intercooler lines down i'd check it real close. Is it smoking more than usual when it's warmed up and under boost? We just had a Cat engine do this and before we could get shut down from 70+ mph it unloaded almost 3 gallons of oil into the exhaust and the charge air cooler, talk about blowing smoke!!!
Good luck and hoping for the best.
yeah, that was my concern, that the thing was coming apart.
the truck does smoke more than I expected under boost, but I thought that was maybe because I was running B100 and it was a little cold outside.
I have another H1C that, while it has a lot more miles on it, looks to be in better shape. I think maybe I'll use that one instead.
Because of the delicate balance in these turbos, is the rebuilding of them better left to a shop, or is this something that can be done in the garage?
Russ
Russ
looks like your turbo seals are gone. Time for a rebuild. Mine was like that was well on my original 1989 turbo. The inside of the xover tube was caked with old black oil. BTW I'm still out of town until this weekend, Whiskey. Do you still want to meet up with the front timing cover gasket install?
Whiskey I have put cartridges in turbos on big trucks with some success, but I feel it's better to let a turbo shop do it since they can bead blast the wheels and most of them have a balancer to balance the assembly. Just my opinion tho. Good luck.
pistazie
ABDTR #5
04-30-2009 08:16 AM
fearthisgoat
01-14-2008 09:24 AM
