Oil Pressure Gauge Questions
Old Mar 2, 2006 | 06:57 AM
BearKiller's Avatar
For oil-pressure gauge, which is best, electrical or mechanical??
I prefer mechanical.
There are two ranges available > 0psi to 100psi < and > 0psi to 200psi <
Which suits the needs of the Cummins??
What type of tubing is used to replace the brittle plastic tube that is usually supplied with mechanical oil-pressure gauges?? brake-line tubing??
Thanks.
Old Mar 2, 2006 | 08:35 AM
kc8ksg's Avatar
I have the mechanical and it goes to 100psi, which I would imagine would be plenty since mine only goes up to 70 at the very most and that is when it is cold usually stays around 50-60 range.
Chris
Old Mar 2, 2006 | 11:35 AM
bgilbert's Avatar
Plain jane plastic oil pressure tubing/boost tubing is fine. Just run it in some flex tubing around the engine back to the 2" gromet in the firewall.
If I were to do it again, ELECTRICAL. No more messing with leaks, trying to tighten the fitting at the oil filter mount, cause it keeps leaking etc etc.
0-100psi is the correct range. COLD + throttle you'll see anywhere from 65-100psi, usually not that high, but possible. Warm cruise 45-55psi, warm idle 20-35psi. Cold idle 60-70psi.
Ripper01
Apr 11, 2006 09:10 PM
streetsmoker
Feb 22, 2006 06:47 PM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
