oil pan gasket
Old May 29, 2005 | 11:26 PM
mopar2ya's Avatar
oil pan gasket
Mine is leaking like a sive fron the drivers side rear of the pan gasket. Can the gasket be changes with the motor in the truck? If so any tricks, do's or donts?
thanks in advance.
Old May 30, 2005 | 12:08 AM
Hemi Cat's Avatar
Yes the pan gasket can be changed with the eng in the truck. Before you drop the pan, check the torque of the bolts and clean the eng off to make sure of the source of the leak.
Old May 30, 2005 | 12:12 AM
mopar2ya's Avatar
Im so positive it hurts. Ive done the rear main twice when I did clutches, just to eliminate it. After a long road trip you could see the oil streaks down the pan.
So do I need to lift the motor a bit or just let the pan drop the inch or so until it sit on the K-frame and then slide the new gaskets in? Any hints are appreciated.
Old May 30, 2005 | 08:59 AM
vavtx's Avatar
I did mine mot long ago when I replaced my clutch. I don't know if it can be done with the tranny installed. With the tranny removed, I removed the fan (to protect the radiator), removed the thru bolts from the motor mounts, and raised the motor as high as it would go. You have to go until the back valve cover hits the fire wall. Go slow and make sure nothing else binds. In that position I could slide the pan back and down enough to get it out and change the gasket. Like I said I don't know if you can leave the tranny installed. Hope this helps.
Old May 30, 2005 | 09:32 AM
mopar2ya's Avatar
Anybody know about doing this if the trans is still in. Thanks for everyones replies.
Old May 31, 2005 | 07:35 AM
mopar2ya's Avatar
bump
tex23455
Jul 25, 2007 02:31 AM
bostongsx
Sep 25, 2006 11:25 PM
Common
Aug 24, 2006 06:31 PM
vavtx
Jan 6, 2005 03:36 PM
Diesel-Dan
May 26, 2004 04:42 PM
