not what i expected
Old Mar 27, 2009 | 06:07 AM
bradshaw106's Avatar
thanks for the replies! as far as egt's when i was pushing 20lbs i was climbing 1200+ my exhaust housing is the 18.5 i have a 12cm it doesn't have the back plate that the exhaust bolts to and i thought it was just to small for my app. so i haven't done much. like richie o said im at sea level. again i always thought something was up with my truck, i can't even spin the tires! not that i really want to i just figured it should do it easily. i just assumed my converter was shot and after i got the tranny freshened up then i would see where i stood as far as seat of the pants power. i was pretty shocked when i saw hooked up the gauge. im going to look for boost leaks today. should i take all the boots off the reinstall?
Old Mar 27, 2009 | 09:16 AM
quick update...
i pulled my boots off didnt see any rips. although their was what looked like slices on the top layer of rubber but didn't go all the way thru. im going to clean them up and put them back on. see if that helped
Old Mar 27, 2009 | 08:24 PM
Richie O's Avatar
366 Spring Chicken
The only way to check for boost leaks in the whole system is to pressure test the whole intake system from turbo to engine by adding compressed air to turbo inlet. There must be a thread explaining what to do. If you can't find it let us know. Someone will work you through it.
Old Mar 27, 2009 | 08:28 PM
I don't think you have a leak.
Old Mar 27, 2009 | 08:31 PM
Richie O's Avatar
366 Spring Chicken
I don't have any numbers with a stock turbo to compaare to. Im sure you do. I switched all my stuff before ever driving my 93.
Old Mar 27, 2009 | 09:35 PM
RollinCoalSmoke's Avatar
I know I don't have a leak. I took it loose at the turbo and the intake and pressure checked to 35psi and left it on there for a couple of hours with no drop in pressure. I was surprised that I had 0 pressure loss. Just need to change out turbo, trans, sticks, and lift pump. When a Goat gets passed by a stock chevy hd 6.5 turbo it's time to park it or fix it.
Old Mar 28, 2009 | 07:01 AM
im just going to wait untill i get my converter installed and see what happens. i did get some more driving time. i get about 7lbs anything above that i have to really push the engine. could it be a fuel problem?
Old Mar 28, 2009 | 09:36 AM
wheres your boost gauge hooked up?
Old Mar 29, 2009 | 12:03 AM
deerslayer1979's Avatar
I think you need to upgrade the tranny and TC. That is more than likely the problem.
DS79
bradshaw106
Jun 27, 2008 11:59 PM
westexhunt
Oct 4, 2007 10:00 AM
pwirch
32
Mar 1, 2007 06:34 PM
440FURY
Feb 9, 2005 04:28 PM
PaulB61
Sep 11, 2004 11:39 PM
