NON Tilt Wheel Ignition Switch
Old Aug 18, 2017 | 06:42 PM
edwinsmith's Avatar
I've looked through the stickies but I haven't found anything on replacing the ignition switch for an 89 with a NON tilt wheel.
Is it easier to remove the speedometer cluster to get at it? Is there a procedure to adjust the switch so it works properly?
Thanks
Edwin
Old Aug 19, 2017 | 07:03 AM
maybe368's Avatar
Thanks
Edwin
Edwin, the 89 should be the same as the 90, but I don't know for sure. Here is my ignition switch replace thread from the sticky:
https://www.dieseltruckresource.com/...-wheel-312883/
It is a bit tricky, but not too bad. If my instructions are clear as mud, that would be about right ...Mark I just realized that you are talking about the switch, not the cylinder. It is located down on the steering column and is actuated by a metal rod. It is a pretty easy job on my 90...
samiam4
Jun 22, 2016 12:55 PM
maybe368
Jan 28, 2016 02:36 PM
mglassburn
Jan 30, 2015 10:36 PM
ScarecrowNJ
Feb 27, 2009 10:28 AM
