NON Tilt Wheel Ignition Switch
I've looked through the stickies but I haven't found anything on replacing the ignition switch for an 89 with a NON tilt wheel.
Is it easier to remove the speedometer cluster to get at it? Is there a procedure to adjust the switch so it works properly? Thanks Edwin |
(Post 3333094)
Is it easier to remove the speedometer cluster to get at it? Is there a procedure to adjust the switch so it works properly? Thanks Edwin https://www.dieseltruckresource.com/...-wheel-312883/ It is a bit tricky, but not too bad. If my instructions are clear as mud, that would be about right [duhhh] ...Mark I just realized that you are talking about the switch, not the cylinder. It is located down on the steering column and is actuated by a metal rod. It is a pretty easy job on my 90... |
