No taillights
Old Feb 10, 2010 | 06:35 PM
B-North's Avatar
No taillights
So I was driving along and suddenly my dash lights went out. I still have all the important ones just no backlighting to my gauge cluster. I have headlights, reverse lights, and brake lights, but no rear taillights. Has this happened to anyone? Would love an easy fix before I go tearing into the wiring with a test light.
Ps fuses all look good.
Old Feb 10, 2010 | 06:46 PM
93-12Smoke's Avatar
Dash lights and tail lights are usually on the same fuse. May wanna check that one again.
Old Feb 10, 2010 | 06:54 PM
bubbared's Avatar
something similar happened to me, ended up that one of the wires on the headlight switch plug had come loose and was no longer making a connection
Old Feb 10, 2010 | 08:34 PM
schamran's Avatar
You probably grounded out and lost a fuse. I bet your front marker lights don't work either. Do you have wiring for trailer lights? Check the wiring there after you check the fuse.
Old Feb 10, 2010 | 08:39 PM
rebal's Avatar
also look at all the fusible links that's a common trouble spot
Old Feb 10, 2010 | 08:41 PM
Check the cigarette lighter for a dime. BTDT.
Old Feb 10, 2010 | 09:47 PM
dzl_damon's Avatar
Happened on my Ford and it was the headlight switch (just worn out, slight evidence of heat). They would come on sometimes a few bumps later or if i played with it a bunch. I've read it's an issue here too I think.
Old Feb 11, 2010 | 11:52 AM
B-North's Avatar
Ok thanks guys. I went through the fuses taking a closer look and found a sneaky bugger that was just barely blown. Kinda interesting cause last time I lost just the dash lights and replaced that fuse. It appears the dash lights gets power from two places or maybe the blown fuse was still making contact for awhile. Anyway she's all good now thanks for the help.
biggerkin
Dec 31, 2006 06:12 AM
mysterync
Nov 9, 2006 11:36 AM
GEN3TRQMONSTER
20
Oct 28, 2006 03:13 PM
tweeter
15
Nov 8, 2005 01:37 PM
