No Speedo Today
No Speedo Today
New wrinkle. Don't know if it's related to the other problems. Maybe my PCM is starting to flake out...
Thoughts??
Thoughts??
pull your speed sensor/reducer off of the gear that it rides on in the transfer case, then stick it back on, some times they decide to slide off and back on then sometimes just off and stay off for good. its worth a try i guess..
Anyway, I looked at it this morning and scared it enough to start working again! I must have a bad ground somewhere.
I didn't mean to contradict you, but the schematic looked like the VSS goes into the PCM.....
I know with my truck, if I really honk on it the speedo and odometer both cut out. When I look underneath I can see that the speedo sensor has hit the bottom of the floor boards. I know I need to install new motor mounts and more then likely also transmission mounts.
Just something to look into.
RHC
02-25-2003 08:27 PM
