No radio!
Old May 26, 2007 | 03:28 PM
rbrettctd's Avatar
Angry No radio!
My radio has been on fritz for quite a while. Would static and sound go out when hit a bump. Now, just to hear static for a split second, I have to slam the door, but thats it. Display stays on, but sound quits. I just soldered everything to make sure, but that wasnt the problem. Any clues?
Old May 26, 2007 | 05:06 PM
Sounds like the radio is shot. Any Chrysler radio from about 1985-1998 will plop in like it grew there, or you can replace it with an aftermarket radio.
Old May 26, 2007 | 05:14 PM
rbrettctd's Avatar
Well it was an aftermarket radio. JVC cd player. I have 2. So that was the first thing I tried. Im thinking the jvc connector may be bad.
Old May 26, 2007 | 05:20 PM
BigTXDually's Avatar
Well if you happen to have the stock speakers still in the doors they could be the one that are pre-amped and a bad connection will do what you are saying. I had this problem in my 01 and it drove me nuts because I had ben installing radios and speakers in my vehicles and others for years. Check it out and maybe that will fix it.
Old May 26, 2007 | 06:46 PM
rbrettctd's Avatar
I dont think stock speakers in a 91 were preamped. They have been replaced anyway.
Old Jun 1, 2007 | 11:04 PM
rbrettctd's Avatar
Okay I need some help pretty bad...Been fighting this for weeks now, and I Cant STAND no radio! Ive replaced the harness between factory wiring and radio, resoldered it all. Still nothing. Could this be an antenna problem, or what? I am stumped. Anybody?
Old Jun 1, 2007 | 11:20 PM
TheRancher's Avatar
Does it make sound with a cd? Or do both radio and cd exhibit the same symptoms? Also, how many speakers? Just the 6x9's in the doors, or more? If you are not getting any cd or radio, by what you describe it sounds like your speaker wiring may be shorting somewhere. Have you checked that already?
Old Jun 2, 2007 | 12:02 AM
airmen65's Avatar
check the magnets on the speackers for rust.... same thing happened to my toyota one day when wheelin. rust in door broke off and fell on magnet, breaking the curcit. few brushes with my hand and i was blastin country again.
Old Jun 2, 2007 | 09:39 AM
rbrettctd's Avatar
No radio, no cd, and no usb (its a fancy radio). Just 2 6x9s, but their only a year old, and theres no rust to be found in or out on my truck. If one speaker wire shorts, would that cut both of them out?
Old Jun 2, 2007 | 10:02 AM
Rampage1967's Avatar
It may, because the deck may have an overload shutdown circuit in it.
Old Jun 2, 2007 | 12:35 PM
93beater's Avatar
no randy if 1 shorts then its just that 1 thats cuts out, and the others will still paly. my best guess would be a ground or harness. i say drive up to ft. worth and have some1 tinker it for you, got mine done for 40 bucks and couldnt love it more, good luck man!
Old Jun 2, 2007 | 01:00 PM
rbrettctd's Avatar
WEll lucky for me my exmechanic paramedic brother finally has a day off tomorrow, so I can recruit him to fix it up.
Old Jun 2, 2007 | 01:02 PM
I have had a deck that cuts them all before . . .
but yeah, a ground or power problem can do some weird things too/
Old Jun 2, 2007 | 01:07 PM
rbrettctd's Avatar
I thought it was deck at first, but 3 decks=same problems.
Old Jun 2, 2007 | 01:37 PM
Big Rich's Avatar
Get a Catholic Preist to do a exorcism
Have you teied a different ground (I expect that you have at this point)
