New truck
Old Jan 21, 2018 | 07:45 AM
  #91
Nice work on those brackets!
It looks like you just repurpose the front of the rear leaf spring hangers to the rear of the rear?
Old Jan 21, 2018 | 09:33 AM
  #92
cabtruck's Avatar
That’s exactly what I did. worked out good. Going to Install the other side today paint rear of frame and reinstall bed then build my new rear axle
Old Jan 21, 2018 | 10:10 AM
  #93
Did the front bracket fit in the factory holes of the frame in the rear?
Let me know if the parking brake bracket gives you any trouble on the drivers side.
I am watching this mod. as I would like to lift the back of Poncho at least two inches and don't really love the idea of going from a OEM 3 inch block under there now, to the bigger OEM 6 inch block.
Old Jan 21, 2018 | 10:46 AM
  #94
cabtruck's Avatar
Used the front bottom hole the rear bottom hole is a little off I drilled through bracket and frame made them match upper front drilled new hole in bracket upper rear drilled hole in frame mine is about 4” lift so I’m going to a 2” block no more 6” block
Old Dec 4, 2018 | 09:43 AM
  #95
cabtruck's Avatar
Just looked at the last post date hard to believe it’s been almost a year sense I’ve touched the truck. Now to figure out where I left off the plane is to make it run by the end of the week we’ll see how that goes
Old Dec 4, 2018 | 09:59 AM
  #96
Blue Goose's Avatar
times does march on....
Old Dec 5, 2018 | 01:40 PM
  #97
cabtruck's Avatar
I’m working on my wireing cant get gages on work other than the odometer and speedometer is there a difference in the oil pressure in water temperature gauges in the cluster between a 90model gas And 92 diesel.
Old Dec 8, 2018 | 05:01 PM
  #98
cabtruck's Avatar
Finally got to hear the new engine running. The alternator isn’t charging will a bad crank sensor affect the alternator?
Old Jan 5, 2019 | 08:34 PM
  #99
cabtruck's Avatar
New exhaust is done maybe I’ll be able to drive it before long
Old Jan 6, 2019 | 06:02 PM
  #100
cabtruck's Avatar
Found the shifter boot that works it’s for a mustang 1965 to 1968 now I’ve got to install it
Old Feb 9, 2019 | 04:53 AM
  #101
KRB's Avatar
KRB
Any luck getting it on the road yet?
Old Feb 9, 2019 | 05:12 AM
  #102
yes it it will the 92/93 pcm needs to see that the motor is running. But could also be the relay on the inner fender.
Old Feb 9, 2019 | 05:15 AM
  #103
Depends...some 90’s were the old analog switches and gauges,but others were like the later 91.5-93 electronic gauges.
Old Feb 9, 2019 | 06:34 AM
  #104
cabtruck's Avatar
thanks for the information on the wireing I had a brain lapse and didn’t have the computer plugged in. that helped make allot of things work. it’s getting closer to be on the road I’m getting down to drive shafts. bumpers. intercooler. finish brakes. Things like that. I nead to find a fuel filter water separater without the sincer in the bottom every one I’ve had leaked I just want one with a screw on the bottom. Still have to get a good handle from oliver for the driver door need one for my other truck to. Nothing but time and money just haven’t had either lately
Old Oct 20, 2021 | 07:12 PM
  #105
cabtruck's Avatar
It’s been a few years since I’ve been able to work on the truck a lot of things going on but I’m back on it got a remember where I left off and what I had done I need to do I did get the inner cooler done air conditioner condenser re-mounted working on the air conditioning now and it does fit behind the stock grill
