New truck
Question cadtruck ... or anyone else with body experience
Drivers side floorboard is rusting through where it meets the rocker ... gonna replace it in spring... when I pull eve out of the cab to replace floorboard and any other surprises I find I was gonna rhino line the interior... no much snowy muddy wet carpet ... just hose it out ever once in a while
Can rhino liner type stuff be installed over sound deadening material? ... or would rhino liner be sound deadening itself
SD
SD
SD
SD
It would fail.
I would, however, put a spray in bed liner on the underside of the cab, once I had a cab that was 100% rust free, otherwise sealing in the rust, would cause it to rot out from within. At the same time they sprayed the under side of the cab, I would have them do the interior floor area as well, sandwiching the nice, clean metal in between, permanently preventing oxygen and moisture from getting in there.
It would fail.
I found a post a while back about using a mustang shifter boot to fix the lower transmission shifter boot now I can’t find it anyone have an idea of what year car ? My truck has started coming together but nowI’ve got allot of small things got to figure out
Edwin
I think it was a Mustang boots as well, but I can't remember who did that.
Did you try searching the word Mustang?
I bet that word has not be used often on this forum and would guess the thread would come up pretty quickly.
That’s about the only key word I didn’t try I think I found it 79 to 06 mustang I ordered one so we’ll see if it works
